Creating Scratch marks on Tanks
Posted by Anonymous on Friday, February 6, 2004 12:53 AM
What is the Best way to create Scratch marks on tanks as well as some paint chips on some surfaces. Thanks.Smile [:)]Big Smile [:D]
    July 2003
Posted by Dwight Ta-ala on Friday, February 6, 2004 1:08 AM
This is how I do it:
For scratches:
Use dark metallic grey base coat (possibly enamel) and use the desired color for top coat of the tank (preferably acrylic). Use cottom swab dipped in alcohol or acrylic thinner and rub against the acrylic paint. Some paint will be removed exposing the metallic paint beneath.
Or:
After applying the top coat, get a stiff and entangled brush. Dip in a dark metallic colored paint. Brush on a cloth to remove most of the paint. Brush against the surface of the model in whatever pattern you wish to simulate scratches or chipped paint.
Then apply a weathering wash and if desired some rust colored paint on the exposed portions.
For chipped paint:
Use dark metallic grey base coat (possible enamel). Use liquid paper to mask certain areas or spots you would want to expose. Spray desired color for top coat of the tank (preferably acrylic). When the topcoat is dry, rub off the liquid paper to expose the metallic paint beneath.
Expect other suggestions from other members to follow.
Good luck.
Posted by Anonymous on Friday, February 6, 2004 1:08 AM
Have a look at this link.
http://www.missing-lynx.com/articles/other/awpaint/awpaint.htm
Posted by Anonymous on Friday, February 6, 2004 1:23 AM
Thanks Dwight and Micheal. Hey Micheal, How did you do those wavvyyy lines on your tank?
Posted by djmodels1999 on Friday, February 6, 2004 1:35 AM
you can also try using a pencil to leave some scratch marks. Graphite is less obvious than paint.
    November 2003
Posted by MartianGundamModeler on Friday, February 6, 2004 1:43 AM
Great link! I'll have to pick me up some oils tomorrow! Never tried them. Heard they take a long time to dry.
"Some men look at things the way they are and ask ' Why?'. I dream of things that never were and ask "Why not?".--Robert Kennedy taken from George Bernard Shaw's "Back To Methuselah" (Thanks to TomZ2) http://martiangundammodels.50megs.com/index.html
Posted by Anonymous on Friday, February 6, 2004 5:26 AM
Good tip Dj.
I use graphite powder for a lot of really worn areas on afv's. It looks more realistic than most metallic paints.
