Tamiya T-55 Enigma - Done & on the base 8/6
    April 2005
Posted by wing_nut on Sunday, April 22, 2012 3:23 PM
Hello boys... I'm Baaaaack!
Yes, I know he is screaming, "Up yours" but it was the only pic I could findWink
Wow did it feel weird to sit down at the bench.  Started the T-55 Enigma and while it does not look like much of a start... it is HUGE progress, comparatively speaking.
I started the same way i started the T-55 from a few years back... by "crapping up" the welds around the turret and adding more texture.  Squadron green putty thinned with acetone was stipple on then I rolled some "flat' areas with a Micro Chisel handle.  Some acetone was brushed over the surface to soften some of the more harsh bits.  Hard to see the texture but it will be more apparent when it gets a coat of primer to even all the color out.
Marc
Posted by Tojo72 on Sunday, April 22, 2012 3:48 PM
Good to see you back in action Marc.No sense forcing it when life catches up to you,it's a hobby,it should be relaxing,no pressure.looking forward to following your progress,
    September 2005
Posted by treadwell on Sunday, April 22, 2012 6:29 PM
Hi Marc...     I knew ( or at least an over powering feeling ) you were gonna do this  :  )      .......
I could tell by the way you answered Manny's post about the ENIGMA...cool beans man !
treadCool
    July 2004
Posted by wbill76 on Sunday, April 22, 2012 7:30 PM
Off to a good start Marc! Nice to see you back building armor again...looks like this one will be worth following along with. Wink
    April 2009
Posted by deafpanzer on Sunday, April 22, 2012 8:52 PM
Hell yeah it is great having you back!!!  Good start... looking forward to follow your whole build.  I smell a lot of PE work coming up?  Never forget your Marder... Yes
Andy
    December 2010
Posted by TheWildChild on Sunday, April 22, 2012 9:01 PM
i will be following this build with some interest.....i never heard of the Enigma until i saw yamiyas ad in FSM. pretty interseting vehicle. im thinking about adding this kit to the stash. looking forward to seeing it!
1/35 XM77  "Sledgehammer", 1964 Chevy Impala Derby Car
Whats next? Aircraft for Ground Attack Group Build
"I dont just tackle to make a play, I tackle to break your will." -Ray Lewis
"In the end, we're all just chalk lines on the concrete, drawn only to be washed away"- 5 Finger Death Punch
"Ahh, my old enemy.......STAIRS"- Po, Kung Fu Panda
    January 2003
Posted by TomZ2 on Sunday, April 22, 2012 10:30 PM
Occasional factual, grammatical, or spelling variations are inherent to this thesis and should not be considered as defects, as they enhance the individuality and character of this document.
    April 2005
Posted by wing_nut on Monday, April 23, 2012 7:24 AM
Thanks guys.  Good to be back.  I'll try to keep the updates regular .  Just gotta be careful "it" doesn't start to take over again,  sneaky little bugger "it" is.
Marc
    April 2007
Posted by SMJmodeler on Monday, April 23, 2012 8:51 AM
Hey Marc: Good to see you got started on this one!    Can you please clarify "crapped up the welds"...?  I assume you just empasized what was there versus ADDed welding...correct?  I need to add some weld seams on my Tiger and I've found some techniques but I like that tool you have in that photo looks like a nice way to divot softened plastic.  Can you give me a bit more info?, thanks.
Take your time Marc...I know what you mean how this/these hobbies can be an obsession.
    November 2006
Posted by dupes on Monday, April 23, 2012 10:43 AM
SMJ - CAN be an obsession? Apparently you haven't been to my house lately...Surprise
Wingy - looking forward to this one! I've got a couple of "regular" T-55s with aftermarket Enigma conversions waiting in the wings that could use some helpful tips. Big Smile
    April 2005
Posted by wing_nut on Tuesday, April 24, 2012 6:13 AM
Steve, in this case yes, by crappying up all I did was emphasized he weld that goes around the top of the turret.  The molded detail is noting more than some barely perceptible striations.   I know Russians "...can't take a dump without a plan...” but they sure made some nasty looking welds.  The seam from front to back was made with a thin strip glued with Testor's liquid glue, from the pink bottle, and allowed to soften then worked with the tools I made.  The tools BTW way were made after reading this feature on Armorama.  Some great info in there.
Marc
    August 2008
Posted by Pvt Mutt on Tuesday, April 24, 2012 6:36 AM
A hobby you say, I thought a lot of you people see it as a way of life.Geeked
The Wingman is backToast
Tony lee
Shoot Low Boys They're Ridin Ponys
    April 2007
Posted by SMJmodeler on Tuesday, April 24, 2012 11:08 AM
wing_nut
Marc: I did the exact same thing on my Tiger last night...decent results...thanks for the info and the link!
BTW:  You didn't give us much of a pre-build appetizerEats...you know, AM goodies, cool paint schemes, etc.  Do the instructions show anything more than sand color?
    April 2005
Posted by wing_nut on Tuesday, April 24, 2012 2:36 PM
SMJmodeler
BTW:  You didn't give us much of a pre-build appetizer Eats...you know, AM goodies, cool paint schemes, etc.  Do the instructions show anything more than sand color?
Sorry my friend... out of practice.Whistling Color scheme is easy... only 1... Sand.   Markings even easier... none.  I have some MK track ordered but in the mean time I found a set of Friuls I had bought when I got me 2nd T-55A kit.  Looking forward to trying the MK's though. PMMS puts them at the top of the list for being best outline and the different pins used makes them “handed’ as they should be.
My LHS did not have the ABER PE set I want and can't get since the distributors 'round here stopped carry ABER.  Is there a distribution issue that came up in my absence?  Weather will be somewhat light (I know... you must hate to hear thatStick out tongue) since these guys did not get much use.
The armor up stuff in the kit is all too neat and even.  I think the bulk of the time will be sent on adding welds all over the place.  All of the armor blocks are molded on in sections that I am going to cut into individual pieces so they will hang better.  And it will make crapping up Whistling the welds easier.  I will likely scratch new mounting brackets of the armor too.
Marc
    July 2003
  • From: On my kitchen counter top somewhere in central North Carolina.
Posted by disastermaster on Tuesday, April 24, 2012 6:54 PM
SMJmodeler
 wing_nut:
Nice job on the crapping up!  http://www.myemoticons.com/images/humor/poop/bear-pooping-in-woods.gif
    I do that the very same way quite often.
 https://i.imgur.com/LjRRaV1.png
    October 2009
Posted by PANZERWAFFE on Tuesday, April 24, 2012 7:38 PM
Nice to see ya back at it Yes You haven't lost your touch, great work so far.  This will be fun to watch come to life!
Rob
    April 2005
Posted by wing_nut on Wednesday, April 25, 2012 6:11 AM
Thanks PW
Uh? DM?  The same as me?  or the bearWhistling
I am doing things out of order while I wait for the PE set that I ordered from japan to be shipped from PolandConfused
The plan from the beginning was to cut the armor blocks apart to be able to CU the welds at each edge... really bad, the Iraqis were way worse than the Russians...12 of 'em on each block.  I didn't want the hollow side so I filled that piece with resin, glued on the back and cut them with a razor saw.  The kerf was the perfect size.
Added a few more bits and bobs to the turret.  Scartched off and rpelaced to support rods for the gun sand cover.  Added a couple of electrical conduits and a hand rail .  The one in the front is .08mm brass tube since it wall have wires coming out of the open end for the search light..  The other end was bent wih a piece of wire inside to keep it from creasing.
Marc
    June 2008
Posted by jtrace214 on Wednesday, April 25, 2012 6:32 AM
looks great so far Marc.Glad to see ya back.Are you gonna make some meetings too? May is two of a kind different scales.I have two Dragon Japanese type 2 amph. tanks done for that one in 1/72cd and 1 in 1/35th scale..
John
the pic to the left is my weekend condo lol
    April 2005
Posted by wing_nut on Wednesday, April 25, 2012 6:37 AM
Thanks John.  Dunno about the meetings yet.. Baby steps. I may come to sell off some stuff as part of the scale back.
Marc
    April 2007
Posted by SMJmodeler on Wednesday, April 25, 2012 8:37 AM
Marc:  Great idea with the resinYes and nice touches on the turret!...what are those little thing-a-ma-bobs on the canvas at the base of the barrel?...DANG they're smallIndifferent!...did you scratch those?!
    April 2005
Posted by wing_nut on Wednesday, April 25, 2012 10:09 AM
Thanks Steve.  Those things are to help hold the shape of the canvas... I assume to keep it from getting caught up in the barrel when it's raised and lowered.  I did that with wire and lead flil.  But I need to get it even smaller.
Pic courtesy of Prime Portal
Marc
    July 2004
Posted by wbill76 on Wednesday, April 25, 2012 12:05 PM
Nice work in the detail department Marc, this one's rolling along at a good clip!
Posted by tigerman on Wednesday, April 25, 2012 1:57 PM
Yay. Good seeing you back where you belong. Wink
I can't recall the other T-55 you did, so this should be a treat.
 Eric
    June 2008
Posted by jtrace214 on Wednesday, April 25, 2012 2:15 PM
Marc,like I said before I wouldn't mind first dibs lol
John
    April 2005
Posted by wing_nut on Wednesday, April 25, 2012 6:21 PM
Thanks Bill, Eric.
Eric, here is a lnk to my Afghan T-55A and nope... it's not a what ifWink
John, I'll try to get a list worked over the weekend and send it to ya.
Marc
    June 2008
Posted by jtrace214 on Wednesday, April 25, 2012 7:29 PM
Thanks Marc
John
    January 2006
Posted by SprueOne on Wednesday, April 25, 2012 8:26 PM
I'm checkin this out. Texture and detail progress looking good. It's just a crazy looking tank
Anyone with a good car don't need to be justified - Hazel Motes
Iron Rails 2015 by Wayne Cassell Weekend Madness sprueone
    July 2003
Posted by disastermaster on Thursday, April 26, 2012 1:01 AM
https://encrypted-tbn2.google.com/images?q=tbn:ANd9GcSTK3UUlTC089Bj8nKB9f0GkZVVI-Gq9VR1RCYZiQCnjMUNgNxiTuY  Great going Marc!
    April 2005
Posted by wing_nut on Friday, April 27, 2012 7:27 PM
Spent some time CU the welds on the added armor.  Got one side got into indy pieces and was experimenting with different methods of roughing up the edges and then coat with liquid glue to soften the look.  Using a medium metal file seemed to be the best way to go making the work go a little quicker.  But tedious none the less.  Lots of edges.  I’ll take a pic or 2 when I do the other side.
The edges of the washer that are welded to the front armor were done with a micro chisel then a 0.7mm resin nut was added.
Marc
    March 2006
Posted by Shellback on Saturday, April 28, 2012 1:07 PM
I like it and i want to see more .Yes
Question , i thought that guy in the 1st post would have been yelling "where's the women ?"..........(think recent events in Columbia )......Whistling
