Now I've done it...
    April 2012
Now I've done it...
Posted by Reserve on Thursday, May 3, 2012 11:14 PM
Just acquired the Hobby Boss 1/35 Sdkfz 222 today. Looking it over the first two things that came to mind were that this is going to be very nice if I don't screw it up and that it's kinda scary. I almost want to hide from it right now. And I thought Dragon kits were fussy. Anyone else tangled with one of these?
Posted by tigerman on Thursday, May 3, 2012 11:52 PM
Can't say that I've seen it myself. Isn't Hobby Boss controlled by Trumpeter?
My feelings are that many of todays kits are over-engineered. Too many parts in sub-assemblies that would be better off with fewer. This is one of the things that Dragon did with their Smart Kits. They simplified the PE they were adding in their kits and reducing the part counts to a more manageable total. Those 1000-piece super kits are gone, but they still pack quite a bit of sprues in the box.
I have a Tristar Brummbar that appears over-done, but that being said, the detail is fantastic in it.
I still like the newer Tamiya kits with 300 parts or so, but just wish they had PE grills and one-piece barrels. But they do go together so well. Big Smile
 Eric
    April 2012
Posted by Reserve on Friday, May 4, 2012 8:58 AM
I could not say if there's a connection between the two names or not it would probably help if I could read Chinese. I like the Tamiya kits also, just fall right together...found one of the seventies release Panzer II's for a ridculously low price last year. Took an afternoon to build and paint and while it is not up to the standards of today's releases it still ain't bad.
Looks like I'll have to get a PE bender now. Might as well get used to it I guess.
Posted by Rob Gronovius on Friday, May 4, 2012 11:38 AM
Yes, Trumpeter is Hobby Boss, according to this article: http://www.cybermodeler.com/special/trumpeter09.shtml
I haven't seen a lot of build ups on the HB 222, but I don't frequent WW2 German armor modeling forums since it is not my main focus. I haven't heard anything bad about it beyond HB forgetting to include the fuel tank.
I think it suffered from market saturation with Tristar, Bronco and Hobby Boss all coming out with the same base armored cars Sd.Kfz 221/222/223.
Here is a discussion from Track Link regarding the HB 222: http://www.track-link.net/forum/modelling_kits/10584
    November 2008
Posted by plasticjunkie on Sunday, May 6, 2012 7:30 AM
The HB kit should be a blast to build. It has a ton of detail, and I think you even get an engine too. Don't be intimidated by the parts count, just take your time and dry fit things first. I built the old Tamiya one that I've had for years. It is very simple and basic but I scratched out a complete interior for it and added a metal barrel and pe screens. It has done very well in the show circuit.
 GIFMaker.org_jy_Ayj_O
    April 2012
Posted by Reserve on Sunday, May 6, 2012 9:45 PM
I remember that Tamiya kit, built one about 15 years ago and I recall it is a sweet kit. I nearly went the same route this time but figured I should try others. Yes, HB gives you an engine, they also give you three frets of photo etch which is something I don't have much experience with. It looks, however,  like I'm about to get some and if I have the willies this is what is causing them. I'm sure that my nifty new PE bender will come to my rescue and the systematic approach will achieve the desired results. Who sez ya can't teach an old dog new tricks. Guess I'll have to document my fumbling here for laughs thanx all for your encouragement.
Mark
Posted by T26E4 on Monday, May 7, 2012 12:01 AM
Before you invest in a PE bender, might I suggest you read some tutorials on how people bend tons of PE w/o them?  I've had mine for many years. I use it 2 or 3 times a year.
I almost all my PE bending with hemostats and a screwdriver or single edge razor and a metal ruler.
Roy Chow
Join AMPS!
http://www.amps-armor.org
    November 2008
Posted by plasticjunkie on Monday, May 7, 2012 7:08 AM
Reserve
Mark
Mark
Nothing to working with pe. My first time was in 1/44 scale and it came out looking fantastic. No fancy tools to use for this task either. I use several tweezers for bending small parts and attaching them, single edged blades for bending the larger parts, and an old bathroom tile for the cutting surface. I use an Xacto small curved blade to cut the pe from the frets. Thick CA or Gorilla Glue, RC56  glue to secure the pe. Hope this helps.
    April 2012
Posted by Reserve on Monday, May 7, 2012 2:22 PM
Oops too late I read you guys reply, I already picked up the bender. Oh well I've always liked precision tools so it's not wasted money.
I started the build yesterday and two things are immediatly apparent. First, this is sort of a borderline evil little kit in that there's quite a bit of flash/ mold line cleanup that needs to be done, the fit is not the best, and some assemblies such as the suspension do not have a positive placement and angle. Dry fitting, filing, adjustment before glue drying, slow going, and look alot are a must.
Second, it looks good, good. Detail is very good throuought and while perhaps not complete it's gotta be pretty close. Be interesting to see it with paint on it.
    November 2008
Posted by plasticjunkie on Monday, May 7, 2012 4:34 PM
Please post some pictures. Sounds like a very interesting future purchase!Hmm
    April 2012
Posted by Reserve on Monday, May 7, 2012 11:45 PM
Seems to me I said I'd do this...thanks for reminding me.
The completed frame. I managed to get one crossmember in upside down and did not notice it until it was too late. #*%&!. It'll not be seen when all's done.
The kit engine before detailing and drybrushing
The photo etch frets
Decal sheet
Some of the more complicated (to me) PE folds. If this turns out right it's going to be in a diorama with another kit I've completed already, will post as progress is achieved. Hope this gives you an adequate appraisal, Plastickjunkie.
Regards,
Mark
    April 2006
Posted by waynec on Wednesday, May 9, 2012 4:20 PM
i have a bender and it works great. had a slight problem w/ italeri pe for MAIALE 2 man chariot submarine (rather strong pe) combined with really narrow bends. worked fine for MAS and LAV-III. will be using it a lot for boats.
Никто не Забыт    (No one is Forgotten)
Ничто не Забыто  (Nothing is Forgotten)
    April 2012
Posted by Reserve on Thursday, May 10, 2012 7:36 PM
A bit of progression...
Base paint on everything except the engine and radiator. The engine is kind of basic and begs for things like exhaust manifolds, distributor and wires, wiring harness, etc but under the circumstances of the planned diorama open engine hatches would be silly. Call me lazy but I don't put alot of effort into things that will not be seen.
The bad side of this kit is really showing up now, lots of tiny intricate parts with mold lines, flash, and not the best fit. It took me an hour of filing and fitting to get the engine bulkhead to not interfere with the upper hull in a dry fit test. I'd feel like I was back in the seventies were it not for the PE and detail offered in it. Bash on, bash on.
    July 2004
Posted by wbill76 on Friday, May 11, 2012 3:01 PM
Coming along nicely! Yes
    April 2012
Posted by Reserve on Saturday, May 12, 2012 8:32 AM
I followed your link, W. Bill, you've been at this awhile haven't you? That's some very good work I was looking at there. Do you do dioramas also?
The gun mount for the 222, about a 30 parts count if I recall correctly...
    July 2004
Posted by wbill76 on Saturday, May 12, 2012 11:27 AM
I've been building armor for about 10 years now, so I suppose that countas as a while. Wink Thanks for the comments on my work, I don't do dios due to space restrictions and lack of interest in pursuing that particular angle. I dabbled a little bit in bases some time back but it just didn't take.
Gun mount looks good, 30 parts translates into some nice detail for it! Yes
    April 2012
Posted by Reserve on Tuesday, May 15, 2012 11:17 AM
Closed up and base painted.
The kit has been a fight, taken much extra time I did not think I'd need but it's not undoable. PE is a pain in the butt. Perhaps I'll get better with practice.
Drybrushing, filtering, and dust time next.
    July 2004
Posted by wbill76 on Tuesday, May 15, 2012 12:05 PM
Moving right along with this one! Don't let the PE get you down, it does take a little practice to get comfortable with it like anything else and the key is always to remember that just because something is provided as PE doesn't always mean that it's better than the styrene options (if available). Pick and choose your battles wisely! Wink
    April 2012
Posted by Reserve on Tuesday, May 15, 2012 4:49 PM
Good advice and well said. I'm thinking of some thin styrene strips to replace the rain gutters above the vision ports, the PE version of which got mangled by my clumsiness. Perhaps a strategically placed tarp will eliminate this problem also as I am not above such chicanery. I'm glad the major portion of this one's behind me, my next one will be a nice, easy Tamiya.
Posted by tigerman on Wednesday, May 16, 2012 11:45 AM
Looking good so far. Keep at her.
 Eric
    April 2012
Posted by Reserve on Friday, May 18, 2012 7:39 PM
Done with construction at last. Hobbyboss sees fit to include the new politically correct DAK palms with the seperate half of the swastika, happily I had some spares from an old Tamiya kit. Need to finish beating it up and dirtying it, then it's on to a base with another kit which I will post on the diorama thread. Where I should have posted my last one. Guess I can be taught.
Thanks for the encouragement, guys. This one came close to ending up in the garbage bucket a couple of times.
Regards,
Mark
    April 2009
Posted by deafpanzer on Friday, May 18, 2012 8:35 PM
Nice work!!! Yes Hope to see your work here again.
Andy
    July 2004
Posted by wbill76 on Saturday, May 19, 2012 2:04 PM
Not bad for your return debut! Some things you might consider for your next build would be using something like Future (acrylic floor polish) to prevent silvering on the decals and also the application of a pin wash or similar to help add some depth to the details. Nice work and look forward to future projects! Beer
    April 2012
Posted by Reserve on Saturday, May 19, 2012 4:55 PM
Thank you both, gentlemen.
 Deafpanzer, if you're interested I have another post in the armor thread called "New here" and some more of my projects are visible.
Wild Bill, I've heard of guys using Future but I would not know what to do with it. What I usually do is base coat, drybrushing, decal application, and chipping if there is any to be done. That's where this model is at now. Next I airbrush Model Masters semi gloss acryllic clear on, then comes the filter, wash, and general dust and dirt. How do you use the Future and in what order? This may be a better option than the one I use.
Regards,
Mark
    July 2004
Posted by wbill76 on Sunday, May 20, 2012 6:40 PM
You apply the future by airbrush (straight from bottle) before you apply your decals. Apply decals and use setting solution of your choice, once decals are all set, spray a 2nd coat o Future to seal them in and voila! no silvering. Future is a semi-gloss so you can use it in place of the MM stuff and it will also protect for washes, filters, etc. HTH!
    April 2012
Posted by Reserve on Sunday, May 20, 2012 11:35 PM
Sweet. I'll try this on the next project for sure. Thanks for sharing this, it would not have occured to me.
