Constructing Tamiya Tank Tracks
    November 2010
Posted by IanBeginner on Thursday, May 10, 2012 10:13 PM
As a beginner I am going to start my 4th tank model, Tamiya's Panzer Kampfwagen IV Ausf.D. The problem I see ahead is putting on the tracks after constructing them by melting the pin heads with a heated srewdriver blade. How do I get the tracks on after attaching the road wheels, Idler wheels, and drive sprokets? I had the same problem wirh Tamiya's Panzer Kampfwagen II Ausf. F/G Kit. I managed to get the tracks on but it was a worry. Any suggestions?
Posted by tigerman on Thursday, May 10, 2012 11:07 PM
I would glue the wheels and idler on and leave the sprocket off until you put the track on. Slip it under the tracks and assemble them last.  HTH.
 Eric
    August 2005
Posted by Phil_H on Friday, May 11, 2012 12:08 AM
As most Tamiya kits mount the wheels using poly caps, it's not often a problem. Often, the easiest way is to mount the sprocket and idler wheels, mount the track on those and then insert the roadwheels. The tracks on the Pz.IV range are moderately tight, but not overly so. It can be tricky, however, when the tank has interleaved wheels such as in the Panther and Tiger families.
    January 2005
Posted by dood_dood on Friday, May 11, 2012 1:00 PM
In the past, i've run put the tracks on last, and hold them in place with alligator clips, with the pins inserted in holes.  Then melted them with the tracks in place.
Now, I using join the before putting them on, either leaving the drive sprocket off until last, or put the tracks on the drove sprocket, streached around the ready idler, and slowly rotated the drive sprocket while working the flexible track slowly in to position over the roadwheels, kinda like putting a bicyle chain on.
