thread for cable
mgh
    May 2011
thread for cable
Posted by mgh on Sunday, May 20, 2012 4:53 PM
I built an Italeri Staghound that came with colored thread for a tow cable.  I am now working on the cheap little Tamiya British Quad Gun Tractor.  It has a spool for a winch, but the kit did not come with any "cable".  I rummaged around in the wife's stuff until she told me to get the heck out of her stuff, but all her thread was too thin anyway.  So what do you all use to simulate cable?
Thanks!
    March 2006
Posted by Shellback on Sunday, May 20, 2012 5:52 PM
I cant think of the diameter now but for me the best is a nylon thread ........no fuzz and the spirals look just right to represent wire rope .
Wire rope example .....
    May 2012
Posted by SANDMAN0198 on Sunday, May 20, 2012 6:09 PM
TRY USING THIS I NORMALLY USE THE CABLE TO HANG PICTURES THE SIZE IS ABOUT RIGHT FOR 1/35 BUT I KNOW IT COMES IN THINER SIZES TOO.  YOU CAN GET IT JUST ABOUT ANY PLACE IS NOT THAT EXPENSIVE AND IS MADE OUT OF METAL JUST TAPE THE ENDS TIGHLY BEFORE CUTTING ONCE YOU GLUE THE CABLE LOOP ON THE TIP OF THE WIRE REMOVE THE REMAINER OF THE TAPE ATTACHED TO THE CABLE AND WEATHER IT ANY WAY YOU WANT TO FROM ACTUAL OIL FROM YOUR CAR OR THE REGULAR WEATHERING TECHNIQUES.  GOOD LUCK
    July 2004
Posted by stikpusher on Sunday, May 20, 2012 7:53 PM
I like using the "guts" from 550/Parachute cord. There are five strands of nylon cord inside the nylon sheath. A few feet of cord will give you enough to do a battalion's worth of vehicles.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
Posted by T26E4 on Sunday, May 20, 2012 8:45 PM
Winch cable has a much smaller diameter than tow cables.
Here's what I use: I get silver embroidery thread (from Michaels).  It doesn't have loose fibers, is the right diameter, and has a bit of texture to simulate the winch cables.
Roy Chow
Join AMPS!
http://www.amps-armor.org
    July 2006
Posted by redleg12 on Sunday, May 20, 2012 9:03 PM
I like to use ship modelers waxed rope and paint it a steel color
Here is the winch from my M4 tractor. The rope is painted with Alclad Steel
Rounds Complete!!
"The Moral High Ground....A Great Place to Emplace Artillery."
    January 2003
Posted by TomZ2 on Sunday, May 20, 2012 9:07 PM
Get “makings” (esp. A. C. Moore, Michaels). Shop selections of bead chain and chain.
http://www.beadjewelry.net/storage/2009/0609/michlayout.jpg?__SQUARESPACE_CACHEVERSION=1256144166428
Tags: chain , makings
Occasional factual, grammatical, or spelling variations are inherent to this thesis and should not be considered as defects, as they enhance the individuality and character of this document.
Posted by T26E4 on Monday, May 21, 2012 12:02 AM
Bill: It strikes me that you don't have enough cable.  Your spool seems rather "skinny".  Photos show quite a bit of cable -- where the wound cable almost encompasses the entire diameter of the spool base.
Here's what I do: I take a piece of styrene rod and cut it to the exact length of the space between the two spool bases.  Then I split the cylinder down its length and insert it into the spool and glue it into place.  Then I superglue one coil of thread around the styrene cylinder.  This masks the cylinder and it appears to be a HUGE coil of winch cable.
I've done it for every US vehicle I've built that has a winch.  See below -- it looks to be a huge coil of cable but it's only the cylinder covered by one pass of my embroidery thread
Roy Chow
Join AMPS!
