Finally Finished!
    September 2010
Finally Finished!
Posted by Ben323 on Sunday, June 10, 2012 4:45 PM
Hey guys,
Check out what i just finished! A Trumpeter 1/35 ASU-85 and a Tamiya 1/35 M3 Stuart.
I'll start off with the ASU-85. This is a great kit ! All I added was an antenna from RB models. I replaced the unditching log with real wood. To get that nice texture on the log, I actually ran a razor saw along it. I used new techniques on this model too. First time using oil paints on the whole model. I think it looks pretty convincing for a 15 year old modeler. Anywho, there is only one small detail missing and I bet most of you will see it in the pictures. There are no chains holding the log. I couldn't find any chain suitable for this scale, so i'll have to do without it. I weathered the tank to make it look like a well worn tank but still taking care off by it's crew.
Now for the next model, my M3 Stuart! I modified this kit by using a Verlinden 1/35 M3 Stuart Early Welded Honey Turret. This set is amazing. Nicely molded and all. Though as you may notice in the pictures, I can't bend those tubes connecting the exhaust and the engine. Impossible task, so I left them off Big Smile. I added a wire antenna that I made out of piano wire. I also replaced those grab handles with wire and filled in the huge open spaces by the back of the tank under the lip. I weathered the tank to look like a tank fighting in France with tons of dust.
That's all for now. I'm pretty happy with my ASU-85 but the M3 is okay. Then again i'm only 15 Stick out tongue. Here is a picture of my "photobooth" Big Smile
Amazing eh?
On my workbench now is a Tamiya M3 Lee and a m117 guardian ASV from Trumpeter. Maybe a BMP-3 too!
Thanks for seeing and reading!
Ben K.
    September 2009
Posted by Hinksy on Sunday, June 10, 2012 5:08 PM
Hey Ben,
Nice work - the razor saw trick works wonders on sheet styrene/plasticard too; you can make some excellent grain effects when you want a couple of planks etc.
I use 46 links per inch chain from tank workshop for most of my chain stuff. They do various sizes-try Googling them.
One trick I was shown was get hold of some wire - diameter relevant to what sort of guage chain you want - wrap it around a pin or tack then remove the coil and bang it flat with a tack hammer. You'll get an effective looking chain. It will be fine for the log. Maybe fuse wire or copper wire taken from some electrical flex. Just weather it up and you'll be laughing!
Hope this helps buddy,
All the best,
Ben Toast
On the Bench - Dragon Pz. IV Ausf. G (L.A.H.) Yes
Your image is loading...
Posted by tigerman on Sunday, June 10, 2012 7:40 PM
A couple of nice builds there Ben. I like that log, it looks very good.
 Eric
    July 2004
Posted by wbill76 on Sunday, June 10, 2012 10:26 PM
Nice work on the pair. Yes
    July 2003
  • From: On my kitchen counter top somewhere in central North Carolina.
Posted by disastermaster on Sunday, June 10, 2012 10:39 PM
http://www.sherv.net/cm/emo/word/omg.gif You're only fifteen?!?!?
Love em both Ben..... more so the  ASU.
Watch out guys http://i35.photobucket.com/albums/d169/bradarnoldweb/emoticons/wow.gif this fella is good.
 Good tip from Hinsky on the chain. I just use a long length of wire folded in half around a paintbrush handle and hold the other ends in a vice grip and carefully twist them in one direction.
 Instead of a tack hammer I use jewelers pliers with a smooth flat surface for a more controlled press and then use tweezers to twist each link 90∘further for added realism.This method allows you to shape them on the model in a more realistic and controlled way.
 If you want to buy a chain I use the ones sold at Hobby Lobby in the jewelry/crafts department (16 inch 44hk printed on the tag). This type of chain may or may not need to be secured in some manner so as to stay in place.
I used one of these on this BT.
http://i20.photobucket.com/albums/b232/gluetank/Smallchain-1.jpg
 https://i.imgur.com/LjRRaV1.png
    September 2010
Posted by Ben323 on Monday, June 11, 2012 10:02 AM
Thanks all for the kind replies!Big Smile
Ya i'm fifteen Disastermaster. I think your BT (-2?) is amazing. I hope i'll get that good !
And I'll try out your technique Hinksy. Thanks for the helpSmile
Ben K.
    January 2003
Posted by TomZ2 on Monday, June 11, 2012 10:15 AM
NICE. Toast
Occasional factual, grammatical, or spelling variations are inherent to this thesis and should not be considered as defects, as they enhance the individuality and character of this document.
    December 2004
Posted by vonryan on Monday, June 11, 2012 10:19 AM
wow sweet builds! Ben323 looking forward to your next builds.
Clay
    April 2007
Posted by SMJmodeler on Monday, June 11, 2012 10:24 AM
Ben323:  This is AMAZING work ...you're 15, really?!?!?  most of us old guys would be proud to call these our own.
There's a lot of talent on this forum..be sure to take advantage of the variety of thoughts and styles.  If you want helpful commentary and critiques on your builds, I suggest posting in-progress photos.  It's more work and it takes more time but you'll find the input to be invaluable.  Also, if you have a topic you need help or suggestions just start a thread...like the log chains.  There's a wealth of knowledge available here!
ASU-85:  Cool subject!, nicely done.
The finish has a bit of a shine, maybe it's the photo but more likely your oil wash needs to be diluted more.  You described this as a well-worn finish...actually this would be considered "clean" by most modelers.   For comparison, check out any of disastermaster's builds...that's the "well-worn" look!   Lastly, You can use necklaces from a dollar store or Walmart for scale accurate chains to secure the log.
Stuart:  I applaud the additional efforts...I admire modelers who challenge themself!!
Antennas are easily made by stretching sprue (keyword search-it).  You said a "ton-of-dust"..again, this is pretty clean by most standards but you did a real nice job applying the dust...very convincing.
photobooth:  Bend (without creasing) a piece of light-weight white cardboard from the arts-and-craft section of Walmart as a backdrop...it's called a "sweep"  You'll eliminate the corner shadow effect.
Thanks for sharing your work...you have quite a future as a modeler!
    September 2010
Posted by Ben323 on Tuesday, June 12, 2012 8:26 AM
Thanks for the awesome tips and feedback SMJmodeler! I will try the photobooth next time I post pictures.
With the oil wash, it was my first time so i didn't know betterEmbarrassed
I'll try to post some in progress pictures of my M117 and the M3 lee.
Thanks
Ben K.
    April 2007
Posted by SMJmodeler on Tuesday, June 12, 2012 9:15 AM
Ben323
Thanks
You're welcome Ben 323, I was a new guy several years ago and there were a lot of gracious veterans willing to help me too.
Live and learn on the oil washes.  Keep it thin, use more coats and let it dry completely between each application. Generously applied  acrylic basecoats seem to help too...they absorb the oil pigment very well and help knock the shine down.
Get the M117 and M3 theads going, let me know when you do...I'd like to follow along!
    July 2010
Posted by Echo139er on Tuesday, June 12, 2012 9:29 AM
Really nice work.  I especially like the photo booth; I think it’s WIP is in order here. hehe
All joking aside  both pieces look great.
    August 2011
Posted by Centerdeck2 on Tuesday, June 12, 2012 6:14 PM
Awesome build!  How did you weather the white 1601 on the asu?
Shepherd Book once said to me, "If you can't do something smart, do something right."
    April 2008
Posted by TZombie on Wednesday, June 13, 2012 5:36 AM
You got a couple of good loking models there. Nice job!
Posted by Bish on Wednesday, June 13, 2012 6:11 AM
Some lovely work there. I think some of the old hands will have to watch there back's Smile
Deffinatly a builder to watch out for.
    September 2010
Posted by Ben323 on Wednesday, June 13, 2012 11:23 AM
I weathered it with oils and some pigments. I used burnt umber, white, burnt sienna, raw umber, raw sienna and some vandyke brown.
Hope this helps Big Smile
Ben K.
