Gonna have problems using sprue.. Getting the tube's taper is is the key... You plan on putting it on a lathe and tapering it? (I use a varible-speed drill for a "lathe") If you don't care about the taper, I'd blow off getting the barrel-length and just "eye-ball" it...
The barrel's length, according to Wiki, anyway, is 118 inches(3 meters) and the M6 is what was installed in the M24.. In 1/72 scale, 118 inches is roughly 1.64 inches or 4.162 cm, if my math is right..
The B-25H-variant was the 75mm cannon-armed variant of the Mitchell, not the J, which had eight .50 caliber machine guns in the nose, vs the four 50, cal/75mm cannon in the nose of the H... The initial B-25Hs were equipped with the M4 75mm gun, but later aircraft were armed with a lighter-weight version, the M5/T13E1...
