Tamiya T-72 Gun Barrel Accuracy
    May 2006
Posted by panzer88 on Tuesday, June 12, 2012 7:28 PM
I'm currently building said kit and I have the RB Models AM barrel for the T-72. I glued the Tamiya one together just compare and noticed a quite noticible difference in the lengths. The RB Models one being almost  a 1/4 inch longer. Does anybody out there which is the more accurate? Thank you.
    May 2004
Posted by Zero Enna on Thursday, June 14, 2012 7:03 AM
Tamiya's barrel is way too short, it seems that the tank they used as reference fpr making the barrel had the gun in recoil position. Eduard's barrel has the same problem, it's just a metal copy of Tamiya's barrel (with separate thermal sleeve brackets). All other aftermarket barrels have the correct length. RB models is OK. HTH. Best regards.
José.
"Vivir venciendo o morir matando"
    May 2006
Posted by panzer88 on Thursday, June 14, 2012 7:50 PM
Thank you very much!! Now I can proceed .
