what type of glue works best on link tracks
    July 2003
Posted by diggeraone on Monday, February 9, 2004 12:06 AM
I would value you alls opinion on what type of glue works best for seperate track
link that comes in so of these armor kits like dragons.I basicly something that you use that is a little flixible or do you just use regular model glue?DiggerSmile [:)]Cowboy [C):-)]Smile [:)]
Put all your trust in the Lord,do not put confidence in man.PSALM 118:8 We are in the buisness to do the impossible..G.S.Patton
Posted by Anonymous on Monday, February 9, 2004 12:13 AM
i use loctite precision super glue on my models and tracks. i paint the tracks while they are at the sprue, cut 'em then glue them. sometimes i use the tamiya plastic cement. it hardens a little longer than cyano.... glues. good for aligning the links.
Posted by tigerman on Monday, February 9, 2004 1:05 AM
I use the testors tube glue, because it cures somewhat slowly, thus allowing more time to shape around the drive sprockets and idlers..
 Eric
    January 2003
Posted by wipw on Monday, February 9, 2004 11:01 AM
I use Tamiya's Extra Thin cement (green cap). It sets up pretty fast, but gives me the time I need to mold the tracks to the wheels.
I do the long, straight runs on a plastic board with a piece of angle glued to it and let them sit overnight. If I have a long section that needs sag in it, I let it set for about 20 mins to a half hour, then push them down onto the wheels and let them harden.
I do short sections and let them dry wrapped around the sprockets and idlers with rubber bands holding them on.
Once I get all the pieces together, I add individual links between them. Kind of like link and length tracks. It works pretty well.
Bill ========================================================== DML M4A2 Red Army ========================================================== ========================================================== -- There is a fine line between "hobby" and "mental illness". (Author unknown)
Posted by Kumy on Monday, February 9, 2004 11:17 AM
Last time I tried model master liquid cement and it worked out nicely. Setup hard but left me with just enough time to shape the tracks the way I wanted them.
Posted by Anonymous on Monday, February 9, 2004 11:59 AM
Me too, Tiger. I want the links to hold onto each other, but I also need some play to get them snuggled into position before the bond is too tight. It's annoying, and takes some getting used to.
Posted by Spamicus on Monday, February 9, 2004 7:51 PM
I use Testors liquid cement. It takes about 20 minutes to set up so it gives one plenty of time to get the tracks installed and lined up.
Steve
Posted by Anonymous on Monday, February 9, 2004 9:43 PM
Ditto Spamicus!
Glenn
Posted by Buddho on Monday, February 9, 2004 11:01 PM
I use what Glenn and Steve use: Testor's liquid cement. It gives me some time to adjust the tracks if I need to..and usually I need to!
Dan
