back to modeling and especially to the dark side!
QUOTE: looked at a gun truck that I built in the 70's and all the panels fell off the plastic truck bed. |
Wow! you mean that happened just from looking at it??? Imagine what would have happened if you'd actually picked it up! lol
Eric is an expert on this stuff. A couple of things I'd add, though:
Rough up the plastic a little at the spot where you're going to attach the pe. It helps give the glue a little "tooth".
Also, make sure your resin or pe is clean before you try to glue it on. And, use fresh super glue! I keep letting mine sit too long on the shelf. I can tell when it's too old because parts just don't stick well. I usually wind up gluing my fingers together before I can get a part to stick where I want it.
Make sure you have either some super glue debonder acetone type fingernail polish remover close at hand. Both for your fingers as well as "over glues".
Again, welcome;
Bill
DML M4A2 Red Army
-- There is a fine line between "hobby" and "mental illness". (Author unknown)
