Making 1/72 SAS/LRDG Jeeps
    May 2012
Posted by Ninja-Viking on Wednesday, October 24, 2012 9:49 AM
OK .....I am starting off.........
First off I need to do a little surgery on the Dragon Jeep body.
Now...on this last pic, there is a lot to do.
In order to mount two (2) spare tires, the location for the mounts needs to be changed.
This is to insure enough room for both tires.
I need to remove both grab-handles, Gas Can mount,
the tire resting plate, and the top of the tow pintle, I'll show why later on that.
Here are the two tire mounts glued in place with proper spacing.
(yes I had to scrafice another jeep for the second tire mounting bracket)
I will fall back onto the Matchbox LRDG set for many of the items,
I will use but they will all get the proper attention before they are added to this project.
    December 2004
Posted by vonryan on Wednesday, October 24, 2012 9:54 AM
good looking start Viking. Yes do like watching your work. but man if i worked on stuff that small i'd jump in front of a busStick out tongue.
Clay
Posted by Bish on Wednesday, October 24, 2012 10:00 AM
Thats some fine surgery there. Some real effort going into this.
    May 2012
Posted by Ninja-Viking on Wednesday, October 24, 2012 10:42 AM
Hi Clay,
There are times when I feel my head is going to explode...lol
    May 2012
Posted by Ninja-Viking on Wednesday, October 24, 2012 10:43 AM
Hi Bish,
There are times I feel my hands shking, then I realize, I need caffene, so I pop a Moutain Dew. :)
Posted by Bish on Wednesday, October 24, 2012 11:33 AM
I know the feeling. I have done some adjustments to 72nd kits myself, but nothing on this scale.
    May 2012
Posted by Ninja-Viking on Sunday, October 28, 2012 8:20 AM
Hi Guys,
Thanks for the incouragement.
I feel that I need to say that the final product may/will differ from you see here.
I will constantly be trying/test fitting different parts to see what works best for you.
That being said.....
by the pic in my last post I had to space out and remount the spare tire brackets,
This is why......., note the "proper" spacing of the spare tires.
Here shows the removing of the slats in the front grill.
Now the "condencer" can from the Matchbox kit seem to be the right scale so I am using it,
However it had two little mounting pins(which I cut off),
I replaced them with one of the removed slats, so that it would properly in the grill.
Now....the dashboard is one of the pieces that you will need from the "donor" kit.
However I needed to modify one for my purposes.
"I" drilled a hole in one to mount the gun pedistle....you will not.
Now I cut up one of the "kits' gun mounts for mounting a .50 cal,
surgerly modified one of my .50's to mount.
This is strictly "test fitting" and my not reflect the final outcome.
Now since I did this, I realised that the .50 sat back too far.
So will look for a different .50 for this purpose.
Now...back to work on other parts.
    December 2004
Posted by vonryan on Sunday, October 28, 2012 10:57 AM
VERY COOL Viking Yes you really have this small stuff downBow Down you know what i fell when it come's to that small work AAAAAStick out tongue  really like looking in.
Clay
    December 2008
Posted by psstoff995's lbro on Sunday, October 28, 2012 11:10 AM
Looking good so far. Keep it up.
-Will young modeler Test fit master
Posted by Bish on Sunday, October 28, 2012 11:46 AM
Another nice update and some more great work.
    August 2012
Posted by Rambo on Sunday, October 28, 2012 5:01 PM
looking good thats alot of small parts
Clint
    November 2004
Posted by Bronto on Sunday, October 28, 2012 7:39 PM
Nice work, DML just announced this SAS release in 1/72 though, so not sure how many you will sell.
    May 2012
Posted by Ninja-Viking on Sunday, October 28, 2012 8:37 PM
They anounced the N.Europe version........I'm doing the N. Africa. (Desert Verion)
    May 2012
Posted by Ninja-Viking on Sunday, October 28, 2012 9:48 PM
Like this:
    May 2012
Posted by Ninja-Viking on Monday, October 29, 2012 8:29 PM
OK......only got a little bit done......
but I think it's worth it.
Here is the final Mock-Up of the M3 .50 cal.
and I am still working on Gas Cans.
I am tring to have the handles as sep. pieces.
    December 2004
Posted by vonryan on Tuesday, October 30, 2012 10:09 AM
WOW REALLY NICE BUILD VikingYes lot of fine detail on a very small build really like watching thisBow Down
Clay
