M1A2 in Iraq Question
    July 2004
Posted by stikpusher on Saturday, December 22, 2012 7:56 PM
I have not had much luck looking up this information. when did the M1A2 variant first see service in Iraq? Was it with the 4th ID when their Tank Battalions arrived in country in 2003? Or was it later with another unit?
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
Posted by Rob Gronovius on Sunday, December 23, 2012 11:51 AM
The only two units to field the original M1A2 in US service were the 4th ID and the 1st Cav (only certain battalions). The 4th did not land in time for the initial invasion because Turkey would not let them land and move through their territory. The straight M1A2 saw service shortly afterwards, at the tail end of the  invasion in 2003. The had to enter through Kuwait.
The above information applies to only the original M1A2 and not the later generation M1A2SEP.
The only other US unit to operate the M1A2 (non-SEP) was the US Army Armor Center and School in training and demonstrational purposes.
    July 2004
Posted by stikpusher on Sunday, December 23, 2012 12:48 PM
Thank you Rob. Yes I do recall all the brouhaha with Turkey and the 4th ID whenit was going on.
At what point did 1st Cav bring in their M1A2's?
       - Plankton
LSM
Posted by Rob Gronovius on Sunday, December 23, 2012 7:49 PM
I do not know. I'm not sure when the 1st Cavalry fielded the SEP. I do know at some point the 1st Cav had a mixture of M1A1D, M1A2, M1A2SEP tanks. I am not sure which ones went in first, which ones didn't go, etc.
I know the 1st Cav fielded the original M1A2, but I do not know if they used them in combat or sent them to Kuwait/Iraq. It may have been battalions with the other variants that went. The straight M1A2 did not have a wide fielding nor a long operational lifespan before it was replaced with the SEP or AIM.
    July 2004
Posted by stikpusher on Wednesday, December 26, 2012 1:56 PM
Thanks for that information. Is there anyplace you can point me for a good overview on the M1A2 operational usage?
       - Plankton
LSM
    July 2004
Posted by stikpusher on Thursday, December 27, 2012 2:23 PM
Next question, what are any external visual differences between an M1A2 and an M1A2 SEP?
       - Plankton
LSM
Posted by HeavyArty on Thursday, December 27, 2012 3:41 PM
The SEP deletes the APU in the rear bustle rack and replaces it with a VCU (Vapor Compression Unit - A/C Compressor like outside your house) and associated armored covers for the tubing that runs under the turret, the left rear hull has been reworked to fit an UUAPU (Under Armor APU) or Hawker Battery System, and depending which type it has (UUAPU) an intake and exhaust on the left side and rear respectively.
I also believe 1 CAV brought SEPs with them on their rotation in '04-'05.
    November 2008
Posted by iraqiwildman on Thursday, December 27, 2012 6:17 PM
I have some photos from late 2004 of 1st Cav M1s, but they are on my work computer. I will remember to post some tomorrow.
Tim Wilding
    July 2004
Posted by stikpusher on Friday, December 28, 2012 1:07 AM
OK, thanks there guys. I will look for some photos of those areas so I can know what I need to do there.
       - Plankton
LSM
    August 2005
Posted by Phil_H on Friday, December 28, 2012 6:10 AM
Also, on the SEP, because the UAAPU or battery module is installed in place of the left rear fuel cell, the fuel filler cap on that side of the (upper) rear hull is not present (compared to the M1A1 and initial M1A2).
    November 2008
Posted by iraqiwildman on Friday, December 28, 2012 12:05 PM
Here isa photo I took in the Fall of 2004 of a 4th Brigade, 1CAV, M1 that was parked outside my hooch. Hopefully you can tell what kind it is.
Tim Wilding
    July 2004
Posted by stikpusher on Friday, December 28, 2012 1:25 PM
Thanks for those bits of info guys. I will look for some photos to try and get an idea of the details you describe. IWM, I do not see the CITV on the turret top, so I will presume that is an M1A1.
       - Plankton
LSM
Posted by Rob Gronovius on Friday, December 28, 2012 1:56 PM
Then you may be wrong; the commander's cupola appears to be the ICWS, a sign of an M1A2 or M1A2SEP.
    July 2004
Posted by stikpusher on Friday, December 28, 2012 2:05 PM
Very true.  Do  components  such as the CITV or ICWS get removed from the M1A2 or added to an M1A1?
       - Plankton
LSM
Posted by Rob Gronovius on Friday, December 28, 2012 2:20 PM
Neither.
The ICWS was added because the commander's screens for the CITV took up the room for the traverse motor for the M1/M1A1 CWS. The CWS had to be redesigned and the ICWS, which isn't really an improvement, was born.
Bottom line, an M1A1 is an M1A1 and an M1A2 is an M1A2.
Now, all M1A2SEPs began life as another variant and are entirely rebuilt tanks, whether they were M1IP or M1A1.
    July 2004
Posted by stikpusher on Friday, December 28, 2012 2:32 PM
Understood. Is it me, missing the CITV in that photo? Or another reason as to why it is not there/visible? I do apprecate all this schooling on the M1 series.
       - Plankton
LSM
Posted by Rob Gronovius on Friday, December 28, 2012 3:09 PM
It may be because of the angle of the photograph. If I increase the view to 400%, it may be visible just above the doghouse, but it is too fuzzy to tell. Likewise with the CWS vs ICWS; when blown up it appears to be an ICWS. Normally when parked, the .50 is parallel to the ground on a CWS. The duck hunter pose of that .50 is more common for the ICWS.
    July 2004
Posted by stikpusher on Friday, December 28, 2012 3:56 PM
That makes sense. I am using my new tablet that I got for Christmas to look at the photo, and have not yet figured how to use this thing for blowing up photos, saving them, etc. Kind of frustrating to figure this thing out... I am not a gadget guy at all.
       - Plankton
LSM
