Brass wire for tow cables - supplier?
    November 2008
Posted by iraqiwildman on Tuesday, March 19, 2013 4:04 PM
I really like how Trumpeter has brass wire tow cables in their armor kits.  I have tried to find this at Hobby Lobby without luck. Anyone know where to buy this wire?
Tim Wilding
    February 2011
Posted by gunner_chris on Tuesday, March 19, 2013 4:52 PM
What about guitar strings?
    January 2006
Posted by dirkpitt77 on Tuesday, March 19, 2013 5:41 PM
Or picture hanging kits?
    "Some say the alien didn't die in the crash.  It survived and drank whiskey and played poker with the locals 'til the Texas Rangers caught wind of it and shot it dead."
    March 2010
Posted by ACESES5 on Tuesday, March 19, 2013 5:48 PM
If you have a Micheal's craft store close by go there I get what is called Beadalon jewlers use it for making bracelets and necklesses. It comes in several sizes I use .012' for WW1 aircraft rigging and for Armor tow cables. Also it's plastic coated so it won't rust on your model over time.                ACESES5  ON BENCH HASAGAWA 1/48 HURRICANE MKII            Welcome Sign
Posted by T26E4 on Tuesday, March 19, 2013 6:25 PM
For very realistic (i.e. not that stuff that comes with the kit or typical picture hanging wire) go for OOK brand.  Look here
www.network54.com/.../Cheap...+and+good+looking...+tow+cables
Roy Chow
Join AMPS!
http://www.amps-armor.org
    January 2003
Posted by TomZ2 on Tuesday, March 19, 2013 6:29 PM
Get “makings” (esp. A. C. Moore, Michaels).
Shop selections of bead chain and chain.
No project is so bad that with hard work and careful
attention to detail it cannot be made worse.
Occasional factual, grammatical, or spelling variations are inherent to this thesis and should not be considered as defects, as they enhance the individuality and character of this document.
    July 2003
  • From: On my kitchen counter top somewhere in central North Carolina.
Posted by disastermaster on Tuesday, March 19, 2013 9:19 PM
T26E4
http://i7.photobucket.com/albums/y269/wing_nut_5o/Armor_2/P1160878.jpg
         THAT            http://us.cdn2.123rf.com/168nwm/quka/quka1207/quka120700050/14526928-3d-little-cute-people-with-cube-orange-head-pointing-up-with-finger.jpg
         is the way to go.
          $3 for 9 feet.
 https://i.imgur.com/LjRRaV1.png
    January 2003
Posted by TomZ2 on Tuesday, March 19, 2013 11:39 PM
Jerry’s Artarama
Brand: OOK® Picture Hanging
Located in: Home, Framing and Matting, Framing Hardware and Equipment, Hanging Equipment, Picture Wire
Picture Wire fits through screw eyes on back of frame for classy and stylish hanging.Braided Professional Galvanized Picture Wire - #2 for small to medium size pictures up to 24×36", maximum frame weight of 12 lbs; #3 for larger size pictures, maximum frame weight of 17 lbs.DuraCoat Gold Plastic Coated Picture Wire - #2 for small to medium size pictures up to 24×36", maximum frame weight of 15 lbs; #3 for larger size pictures, maximum frame weight of 20 lbs.
    May 2009
Posted by Pawel on Wednesday, March 20, 2013 3:17 AM
Hello!
If we're talking tow cables, you don't really want any stiff wire here, unless it's going to be really straight on the model. If you want add a little droop between the points where the cable is supported, you want a soft material - that would be copper. You can make it even softer by heating it up and letting cool. And the cheapest source of copper wire is the electric industry - get even a small length of elastic electric cable and you have a lot of copper there. Sometimes even for free - like a power cable of an appliance to be scrapped. Hope it helps, have a nice day
Paweł
www.vietnam.net.pl
    January 2006
Posted by dirkpitt77 on Friday, March 22, 2013 7:38 PM
I've been trying to think of a way to scratch build a winch for a 1/24 civilian Jeep kit I have in the stash. Winch cables are quite a bit thinner than an AFV tow cable. I wonder if this method will still work.
    April 2005
Posted by wing_nut on Friday, March 22, 2013 8:02 PM
T26E4
Hmmmm that looks vaguely familiarWhistling
Just keep in mind it is still fairly stiff even after annealing but not so much it won't work.
Marc
    April 2005
Posted by wing_nut on Friday, March 22, 2013 8:21 PM
Here is a compassion between the OOK for the main cable and this other stuff for the track cable I found shortly afterward I found the OOK.  The OOK stuff is about 0.04" and the other is about 0.025.  I find it in a crawl space and I think it might be used for security systems.  It is a paired wire, one copper and the other silver colored and both twisted   As long as you get the plastic sheath off with affecting the twist.. it will twist tight very neatly.  And this one is soft and flexible after annealing.  I think the size is 22 gauge but its hard to read on the wire.
Marc
Posted by Rob Gronovius on Saturday, March 23, 2013 11:07 AM
I wouldn't worry about it being too stiff; actual tow cables are very stiff, at least the modern ones are. Any bend or kink in a modern tow cable renders it unusable due to safety precautions and it is replaced.
    September 2009
Posted by Hinksy on Saturday, March 23, 2013 1:36 PM
I have used both plastic moulded cables for use on the deck and sidewall of my Dragon Tiger I Ausf. E but when I have looked into using proper metal kit supplied cables for use on a build it's nigh on impossible to get the loops out of each length to render the lengths straight - like fishing nylon the wire has memory so always returns to it's original circular coiled poistion.
I actually took one length from a Dragon kit and attached a heavy weight to the end (1/4ib's lead). I left this hanging for a whole week and it hardly did a thing!
The best wire I have found was in a Lion Roar DIY Tow-Cable kit. This was excellent stuff and you get to make up some impressive looking tow cables too.
http://www.perthmilitarymodelling.com/reviews/vehicles/lionroar/le35092.html
Hope this helps!
Ben Toast
On the Bench - Dragon Pz. IV Ausf. G (L.A.H.) Yes
Your image is loading...
    May 2009
Posted by Pawel on Sunday, March 24, 2013 8:47 AM
Rob - take a look at the post above yours - isn't the bend in the tow cable on the side of that Tiger radical?
Tim - good luck with your build, have a nice day
Paweł
www.vietnam.net.pl
