Kinda left that open there, firefly!
Which kit and what kind (brand) of pe have you got? Some of it depends on the manufacturer.
General stuff:
-Clean the pe parts with alcohol or laquer thinner.
-I read that if you put some vinegar on them, it will slightly etch the parts and help the glue/paint hold better. Makes sense.
-Bend the parts using tweezers, flat nose pliers, metal straight edges and razor blades. Whatever works best for you and the particular part. If you can afford it, a Hold 'n Fold or Etchmate work great!
-Bend from the inner folds towards the outer folds, generally, but study the part and the folds to make sure you know how it needs to be bent and the best order.
lightly rough up the area on the tank where the part goes. It will help adhesion.
-Dry fit the part so you know exactly where it goes.
-Use fresh, thick (gap filling) superglue.
-Use a tooth pick, wire, etc. to put just a bit of superglue on the part.
I'm sure I missed a few. Others will add to this list and give you alternatives.
Good luck
Bill
DML M4A2 Red Army
-- There is a fine line between "hobby" and "mental illness". (Author unknown)
