Return rollers
Return rollers
Posted by Anonymous on Wednesday, February 18, 2004 9:13 PM
I have two holes in my return rollers...are they ejector pin holes...if so do thet need to be filled with putty?
John
Posted by Rob Gronovius on Wednesday, February 18, 2004 9:19 PM
In what kit? If it is on an M1 Abrams series tank, the rollers are hidden by the skirt.
If on an M4 Sherman series tank, the support roller is basically one big steel bearing. One hole is the grease plug and the other the relief valve so the two holes are supposed to be there.
The list goes on and on based on the amount of tanks that have supprt rollers.
So as you see, the answer depends on WHAT TANK ARE YOU BUILDING?
Posted by Anonymous on Wednesday, February 18, 2004 9:37 PM
It's the Sherman, Rob, thanks for answering yet another of my questions! Cool, this means I don't have to do anything to them...bonus!
John
Posted by Anonymous on Wednesday, February 18, 2004 10:37 PM
Johnpo-
With any ejector-pin mark, on any part, try an decide whether it will be visible on the finished model. If it isn't then leave it alone, there's enough work to do already. If it will be visible then you'll have to fill it in or sand it down!
Glenn
