How can you sculp Braille scale [1:72] epoxy musette stowage?
    January 2003
Posted by TomZ2 on Wednesday, June 5, 2013 2:22 AM
I’ve made putty tarps and air recognition panels for stowage, but I can’t sculpt a decent epoxy musette bag.
The best I’ve seen…
Frogman
Frogman by 03/03/2011, 21:25
How to make epoxy backpacks
Quote:
Originally Posted by shay454 View Post
Great work!
can you explain how you make the backpacks?
Well, since you asked , here is the method that I use. I have a product which I like very much called "Apoxie Sculpt". It is a 50-50 mix. I take a small amount from each container and make a ball which is mixed just with my fingers crushing and rolling over again.
I then stretch it out to a sausage shape so that I can cut equal parts for whatever I am going to sculpt.
I then cut into equal parts with an Exacto knife
I shape with my fingers into a general square shape for a backpack.
Then using a new sharp pointed toothpick, I sculpted some general detail like the backpack flap and I define the edges.
I use a razor-saw with fine teeth to impress simulated stitching on the pack edges.
I roll out some VERY fine epoxy to make the straps.
These are the "Tadaleem" backpacks nearly finished.
These are the backpacks in position on my halftrack. I was not planning to put these here over the tarp cover, but because they turned out so nice they are now part of the general clutter seen on every Israeli track.
So, thats the trick. Not too difficult and believe me you get better as you make more of these. One additional trick is to use water or spit for smoothing out fingerprints and also after you first blend the parts together let them "rest" for about 10 minutes so it won't be so sticky. You have about an hour to work it before it gets too hard.
All the Best,
Ed Okun
[FYI, “Tadaleem” means, I think, “Congratulations”.] Now, does anyone
have anything better, specially for Braille scale [1:72]? Thanks.
Occasional factual, grammatical, or spelling variations are inherent to this thesis and should not be considered as defects, as they enhance the individuality and character of this document.
Posted by Rob Gronovius on Wednesday, June 5, 2013 11:37 AM
    January 2003
Posted by TomZ2 on Wednesday, June 5, 2013 12:31 PM
Rob Gronovius
There is a lot of resin accessories for armor kits in 1/72 scale.
www.onthewaymodels.com/.../manufacturers.htm
Tracks-n-Troops is a shop in Europe that specializes in this scale. Order from there with confidence.
tracks-n-troops.eu/shop
Thanks, but I didn’t ask to “resin” but “epoxy” (or “Apoxie”).
If life gives you melons, you might be dyslexic; it’s all very information.
Posted by Rob Gronovius on Thursday, June 6, 2013 10:08 PM
Sorry, forget I tried to help. I'll remember to keep my thoughts to myself in regards to your posts in the future.
    January 2003
Posted by TomZ2 on Saturday, June 8, 2013 11:31 PM
Another tutorial (Flames Of War) quote:
Bags
Bags and backpacks attached to the side of tanks and halftracks are another common features of armoured vehicles in WWII.
Start exactly like you did for the canvas rolls, make a cylinder of epoxy and cut it to the length you wish.
Then, make some small perpendicular cuts to simulate the shape of the bags.
Step 2 Bags
Step 3 bags
Attach them where you want on the tank (typically the side of the hull or the turret) and with the blade improve the shape by pressing the blade laterally into the cuts you previously made.
Then, press the blade flat on half of the “bag” – to simulate the cover.
When you’re happy with the shape leave it to harden.
To add the straps, make a very small cylinder of epoxy, cut it in short sections and with the point of the blade attach it on the (now hardened) bag.
Flatten it with the side of your blade.
For my tanks, I usually do this work all at once for each single platoon.
Step 4 Bags
[http://www.flamesofwar.com/Default.aspx?tabid=110&art_id=418&kb_cat_id=28]
    August 2007
Posted by DUSTER on Monday, June 10, 2013 7:40 AM
Was There a Question in all of this?
Steve
    January 2003
Posted by TomZ2 on Monday, June 10, 2013 5:11 PM
DUSTER
Yes. How can someone ELSE sculp epoxy musette packs/rucksacks/bags (and other stowage), BETTER than I’ve able to scavenge? Rolls and tarps are easy; M1936 musette bags or M-1944 Field Packs are harder. (Though my geriatric duffel as become positive from “decent”, I’d like my repertory to be superlative!)
    January 2003
Posted by TomZ2 on Thursday, June 27, 2013 12:06 PM
FYI:
http://www.history.army.mil/html/museums/messkits/Field_Mess_Gear%28upd_Jul09%29.pdf
U.S. Army Field Mess Gear
1. Haversacks & Field Packs
The term haversack comes from the seventeenth century Low German word hafersach meaning “a cavalry trooper's bag for horse provender,” literally an oat sack. By the mid-eighteenth century the French were using the word havresac to mean “a single strapped bag worn over one shoulder and used for carrying rations.” This term came over into English with the same meaning.
Smile Dots
2. Canteens
The term canteen comes from the French word cantine meaning “a sutler's shop, a storage vault or a storage corner,” and other similar meanings now obsolete. The term was extended to mean a “refreshment room,” and by 1744 it came to designate a “small container for water carried by solders on the march.” This term came over into English as the word canteen with the same meaning. (Online Etymology Dictionary)
ETC. ETC. ETC. More than I know at 1:1. Now, what about 1:72?
