Tiger 1 fueling
    February 2013
Tiger 1 fueling
Posted by Recon89 on Tuesday, July 23, 2013 4:45 PM
Doing a diorama with a Tiger 1 during re-supply.  Off the wall question, but where was the fuel inlet located?  I have researched a lot of sites, but can not find any data that shows the location.
Thanks.
Posted by Spamicus on Tuesday, July 23, 2013 6:01 PM
Fuels cells were located on both sides of the engine compartment. The filler is under the small round armored cover at the front of the front set of grills on the back deck. The ones between the grills are the radiator fillers.
Steve
    July 2004
Posted by stikpusher on Tuesday, July 23, 2013 6:03 PM
The fuel filler caps are on the forward end of the engine deck on each side in the front center of front grills. The look like a phillips head screw. The similar caps on each side of the engine just forward of the rear grills are for the radiatiors.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    January 2003
Posted by TomZ2 on Tuesday, July 23, 2013 6:14 PM
Some data:
Liejon
German armour is complex.
All fuel tanks are interconnected. The system was filled at the center rear tank (with the filler cap) also the vent/breather lines are interconnected. All vents of the lower tanks lead via the higher positioned tanks to the filler tank.
The driver could select which fuel tanks provided fuel...rear left (top and lower tank), rear right (top and lower tank), or both tanks in the fighting compartment. Selecting the rear tanks included also the center filler tank.
Occasional factual, grammatical, or spelling variations are inherent to this thesis and should not be considered as defects, as they enhance the individuality and character of this document.
    July 2004
Posted by stikpusher on Tuesday, July 23, 2013 6:24 PM
TomZ, I think that is a Tiger II. The tanks are sloped to match the contours of the external sloped side armor.
       - Plankton
LSM
    February 2013
Posted by Recon89 on Tuesday, July 23, 2013 8:56 PM
Thanks everyone for your help.  I knew I could get an answer here.
Posted by Spamicus on Wednesday, July 24, 2013 7:45 AM
I agree with Stik, that's a King Tiger Tom is showing you.
Steve
    March 2008
Posted by EasyMike on Wednesday, July 24, 2013 3:15 PM
See if you can scare up a copy of the old Squadron-Signal Tiger In Action  It's full of black and white reference photos.
Smile
    July 2004
Posted by stikpusher on Wednesday, July 24, 2013 4:31 PM
Didn't Squadron do a "Tiger Walk Around" book fairly recently?
       - Plankton
LSM
    January 2003
Posted by TomZ2 on Wednesday, July 24, 2013 9:17 PM
stikpusher
We apologize for the fault in the image. Those responsible have been sacked.
(Yes, that was a Tiger II.) Kyoshi Harada draw this Tiger I cutaway(s):
