1/48 railcars
    June 2006
1/48 railcars
Posted by Tankluver on Sunday, August 18, 2013 1:51 AM
Do the 1/48 railcars run on O gauge track, or can they run on O gauge track?
    October 2010
Posted by Dogfish_7 on Sunday, August 18, 2013 10:49 AM
Bruce
    June 2006
Posted by Tankluver on Sunday, August 18, 2013 3:34 PM
would you suggest any modifications to the wheels?
    August 2007
Posted by DUSTER on Wednesday, August 21, 2013 4:25 PM
A bit of TMI if you're interested    http://en.wikipedia.org/wiki/List_of_rail_transport_modelling_scale_standards
WHOOO WOO!!!
Steve
    May 2004
Posted by f8sader on Wednesday, August 21, 2013 6:33 PM
Easy answer:  For scale modeling, there are 2 rail tracks for 'O' scale.  I run the more common 3 rail which suits legacy type 'O' cars.
A little more in depth: There is a difference also between 'O' and 'O' scale as far as the accuracy of the car's dimensions; but they both run on the same track.  The exception here is, there are cars which can run on both 2 rail and 3 rail tracks (having one insulated wheel on the same axle), and cars that can only run 3 rail (having no insulation between opposite side wheels on the same axle).  This is due to the way the engines and lighted cars draw power from the track.  Two rail engines draw power from both rails like HO trains.  3 rail have "hot" in the middle rail, and "common" in the outer two rails.  (It's basically an AC system at about 18v. total.)
Lon-ski
    June 2006
Posted by Tankluver on Thursday, August 22, 2013 1:54 PM
I see, thank you all for the information
    September 2005
Posted by richs26 on Saturday, August 24, 2013 12:39 AM
Are you going to do European style cars or American?  Don't do it like that one diorama in FSM a while back that showed the loading of equipment at an English port for D-Day.  American flatcars were used in the dio  which couldn't have actually been used as they have knuckle couplers.  These couplers were never used on European railways at that time as a buffer and chain method was used.
WIP:  Monogram 1/72 B-26 (Snaptite) as 73rd BS B-26, 40-1408, torpedo bomber attempt on Ryujo
Monogram 1/72 B-26 (Snaptite) as 22nd BG B-26, 7-Mile Drome, New Guinea
Minicraft 1/72 B-24D as LB-30, AL-613, "Tough Boy", 28th Composite Group
    June 2006
Posted by Tankluver on Saturday, August 24, 2013 12:50 AM
right now this plan is kind of like an idea, but no I would use bumpers and chain
    June 2006
Posted by Tankluver on Wednesday, August 28, 2013 3:57 PM
where could i get 1/48 and 1/35 european style couplers
