Stuart photos
    January 2013
Stuart photos
Posted by Armyguy on Thursday, November 7, 2013 6:24 PM
 Here's some shots of the Stuart I just finished,like I said in my first post it was a learning experience, it was a half hearted  effort at first so there is a lot of room for improvement.
On my next one I plane 60% research 40% build.
    July 2006
Posted by bufflehead on Thursday, November 7, 2013 7:49 PM
Well Armyguy, I don't know if you were referring to your post or the model, but I think you did a pretty bang up job on the Stuart (called "Honey" by the Brits).  The assembly looks solid and  Caunter Scheme  colors and pattern seem convincing!  The only thing I think it could benefit from is a pin wash to bring out all the rivet detail!  Other than that its a build to be proud of!
Ernest
Last Armor Build - 1/35 Dragon M-26A1, 1/35 Emhar Mk.IV Female
Last Aircraft Builds - Hobby Boss 1/72 F4F Wildcat & FW-190A8
    January 2013
Posted by Armyguy on Saturday, November 9, 2013 1:06 PM
Rob, Stikpusher appreciate your input about  Academy's M3, Ernest thank you for the encouragement.
As I research more about the Caunter Scheme I sense a little debate about  if it was even used on Stuart's, how many colors were used and what shade those colors were.
I've read William Marshall's article Bellman story of a Stuart and used some of the information to paint my model (in looking at it for the sixth time my interpretation of the flash on lower hull is wrong) and will use more of it on my next Stuart.
Dave
On the work bench Revell 1/48 P-47D razorback. Trying some thing different.
    April 2006
Posted by jgeratic on Saturday, November 9, 2013 3:54 PM
The execution looks quite good, and I'm sure with more builds under your belt, you'll want to try some weathering.
You should check out Mike Starmer's work on British vehicle colours:
http://www.mafva.net/other%20pages/Starmer%20camo.htm
In his research, you will find that the caunter scheme was no longer to be applied to new vehicles  as of October 1941, with the provision of one disruptive colour only.  So Stuarts could have the proper three colour scheme, just depends when they arrived.  During the Crusader battles, the latter was probably more likely, but one can't be pandemic about this, as it was war time and repaints can't be assumed to have been implemented immediately.
regards,
Jack
    January 2013
Posted by Armyguy on Saturday, November 9, 2013 5:57 PM
Jack  Thanks Mike Starmer's article is very informative .
 I do have to work on the weathering, tried some on some Jeep models not so good.
 Starting to add resin and PE to my repertoire.
Dave
