"First" Willys MB jeep build
    March 2013
Posted by MikeyBugs95 on Sunday, December 15, 2013 9:30 AM
I had recently received this kit after about a week of waiting for delivery. About 5 days ago I opened the box up and then, later, started to work it a bit.
Now, 4 days after painting, I have the chassis assembled, with the exception of the wheels, and have started on the body.
I'm wondering how the weathering is and what I should do/add to it to make it better. Unfortunately I have no pigments, pastels, powders, etc to choose from. Just enamel and acrylic paints and brushes.
Here's the body and wheels...:
Anything to help the wheels out?
And the .30 cal mg:
(I know, I have to make the gun darker and paint the grip brown.)
Any tips and/or suggestions?
 In progress:
CAD:
1/35 SINCGARS ICOM/ASIP; 1/35 Flat screen TVs; 1/35 tactical light that I shall reveal later Devil
Models:
1/35 DML M4A1 DV; AFV Club M18 Hellcat; DML StuG IV; DML Armored Jeep w/ .50 cal; Panda Cougar 4x4 MRAP; Academy M3A1 Stuart; 1/700 Midship Models USS Miami; 1/700 Skywave Rudderow Destroyer Escort
    January 2013
Posted by Armyguy on Sunday, December 15, 2013 8:35 PM
Well looks like I'll have to keep an eye out for you on two forums.
Dave M
Posted by Rob Gronovius on Monday, December 16, 2013 4:23 PM
Are you sure the grip isn't the same color metal as the gun itself?
    March 2013
Posted by MikeyBugs95 on Monday, December 16, 2013 4:53 PM
I dunno. I've seen various pictures of the gun and have seen it with a wood/brown color grip as well.
 In progress:
CAD:
Models:
    November 2013
Posted by MRME on Monday, December 16, 2013 5:44 PM
Ive seen both, think it depends on age of gun dont really know though
anyone needing/wanting info about me contact me a richduddy@gmail.com. I only give info about myself on a need to know basis.
    November 2013
Posted by MRME on Monday, December 16, 2013 5:49 PM
PS forgot to add grease up the joints a bit steering knuckles etc. looks good otherwise
Posted by CapnMac82 on Monday, December 16, 2013 10:04 PM
The M-1919 was issues with a bakelite and a rubber grip, but the collectors tell me those are very rare for not lasting long.
Both walnut and birch were used for the grip.  The latter were stained dark before having boiled linseed oil rubbed in.  One thing about BLO is, that when left in the sun, it can 'cook' to a rather dark color.
WWII Parkerization had a distinct green cast--drop of green zinc chromate, drop of black green added to Steel will get close.    After the war and through KW, the parkerization spec changes to a charcoal grey--about equal parts Steel and Sooty Black (or use Burnt iron with a couple drops of Aluminum--I've not tried that mix).
For 1919 barrels, my method is to paint barrel & shroud in NATO Black.  Let that dry, then 'wet' drybrush the shroud in a mix of Steel and Oily Black.  if you are really tough, a 2H pencil will give a nice highlight to the barrel--but you need a ruler, a magnifier and a base course that keeps the ship's roll to a minimum.
Now, for colorful, nothing but nothing beats the Browning 1917.  Receivers are often Colt's Imperial Blue.  The cradles have bronze and brass and plued as a well as phosphated parts.  The end caps on the water jacket are a brass color, ranging from pale bronze to brass to gold.    The tripods are usually a Medium Green (the 4-clor NATO, not the SEA air force).  Although a replacement leg in OD is often seen.
Ok, so the Brit Vickers has even more color combos--but, I stick to US subjects.
