After all that hand-wringing, I sat down to tape the things, said, oh what the heck" (I'm paraphrasing
) and did it freehand.
I did the numbers on one side of the turret. The numbers -- 5 3 and 2 -- had to go over the Mirage resin zimmerit, and the 3 had to go partly on the pistol port as well.
The 5 and 3 went on fine with the recommended blunt lead pencil method. For settling it into the zimmerit, I used a dry, fairly large paintbrush with stiff bristles to push the transfer in, and parts of the 3 onto the pistol port. I'm not sure how firm the connection is, but at least they seem to be on there.
The problem was the 2. Despite a great deal of rubbing on, large parts of it just did not want to stick. Finally, desperate that it was ever going to transfer, I just lifted the paper and tried to get the number to separate from the clear plastic. It mostly did, but the bottom tail of the 2 wrinkled and then settled on the model.
I was pretty disappointed, as I had done everything I was supposed to do. Then I just scratched off the tippy tail of the 2, and made a few more scratches in the number, and it actually wound up looking pretty convincingly like the paint was wearing of chipping off. Phew. It actually looks kind of authentic. I went back and did the other numbers as well.
Still, I am worried that I will have even worse problems with the numbers on the other side, and on the back ot the turret. If I do, that might end my experiment with dry transfers right there -- at least on zimmerited tanks.
