Mirror Models 1/35 Diamond T 969A wrecker WIP
    February 2010
Posted by Stage_Left on Friday, February 21, 2014 9:19 PM
Ok- I thought I'd do something other than comment in the 'Musicians in the Forums' and 'How many kits in your stash' threads.....although, don't misunderstand, those are fine threads!
I'd been bugging my fantastic wife about this kit since I saw the announcement last spring. I just think support vehicles are cool, and I was curious about this 'new kid' on the manufacturers' block. As a Christmas present she told me to order it when it became available, so Sprue Brothers got it in the last week of December and I had it by Jan. 4.
I started it immediately and .....wow. The box says 570 parts and I believe it; the box is jammed full. The detail is amazing and there are virtually no mold seams or knock-out pin marks, but the sprue gates are large and I've used a razor saw to cut almost all the parts I've used so far from the trees. This is no mean feat as there are a LOT of fiddly bits, some hardly bigger than the end of a pair of tweezers.
As a result of the large sprue gates there's a lot of cleanup, and there are many small gaps that (as I see it) need filler of some sort or another (to this point I've used gap-filling CA, Squadron white putty thinned with Testors' liquid cement, and Mr. Surfacer 1000).
Anyway, here's where I am now. I'm historically a glacially slow builder but I've made the commitment to stay with this one. Squadron's Diamond T 4-ton Truck Walk Around and Ampersand Publishing's Heavy Wrecker have been very helpful references.
The Hercules RXC flat six contains 45 parts, and the Kellogg air compressor 21. The copper wire is the first of the six spark plug wires:
Chassis:
Left and right service drums for the boom winch cables, oxygen and acetylene bottles, and front axle. Cool engineering here: the brake assemblies really do turn side to side:
Body with tool boxes (minus lids) and radiator assembly:
Wheels- L-R: front, spare, rear dual:
That's it for now; comments/critique welcomed.
Dave
Posted by jeaton01 on Saturday, February 22, 2014 12:46 AM
Hope you can get some pictures up, sounds interesting!
John
    May 2009
Posted by Pawel on Saturday, February 22, 2014 1:49 AM
Yeah, I love that kinda stuff too! Good luck with your project and have a nice day
Paweł
www.vietnam.net.pl
    February 2010
Posted by Stage_Left on Saturday, February 22, 2014 9:35 AM
John and Pawel- thank you both for dropping by, I do appreciate it! Sorry about the pix, I forgot to make the folder 'public.' I can be a noob sometimes Black Eye I think I've got things sorted now Big Smile
Dave
    November 2008
Posted by mrmike on Saturday, February 22, 2014 10:23 AM
Interesting and unusual subject - looks like a great winter project. I'll be following your WIP.
    July 2003
  • From: On my kitchen counter top somewhere in central North Carolina.
Posted by disastermaster on Saturday, February 22, 2014 9:05 PM
Hey man, this is gonna be "the cheese".
http://www.moneymappress.com/pro/images/0813_MMR_Obamacare_MGA.gif
 https://i.imgur.com/LjRRaV1.png
    February 2010
Posted by Stage_Left on Monday, February 24, 2014 1:16 PM
Mike and disastermaster- thanks to you both very much for dropping by and for the nice words!
I'm working through the suspension and drive train, and I hope to have another update in a couple days. There's quite a bit to it but I'm very pleased with the attention to detail and thought that was put into the design. Despite the fuss I'm giving every little assembly (or maybe because of it....) I'm really enjoying this build!
Thanks again for the time guys!
    February 2010
Posted by Stage_Left on Monday, March 10, 2014 6:25 PM
Phew- finally an update! Most of my time has been devoted to the rear suspension and drive train; it is quite complex. Practically every component is its own piece: brake air chambers, their mounts and actuators, the rocker beam and it's two hub ends, spring seats, torque rods (upper), torque rod brackets, rocker arms (lower)....you get the idea. For as many parts as there are it all fits well and gives a good representation of the real thing.
Things get even more interesting when it comes time to install the drive shafts. It's a veritable spider's web between the frame crossmembers and the rear suspension assembly so installing the drive shaft that connects the two differential carriers that sit on top of the two rear axles, and the two U-joints that connect to the differential carriers, takes some time and patience. Tolerances are very tight so I had to carefully shave off some material between the carrier and U-joint mating surfaces, although I didn't take any material from between the U-joint to U-joint.
All the U-joint assemblies that mate to the differential carriers/transfer cases/transmission are separate pieces (the drive shafts and their U-joints are one piece), and it's at all these mating surfaces that I had to remove some material to squeeze in the drive shafts just like I did between the differential carriers.
For anyone building this kit (or considering it), the keyhole that aligns the forward differential carrier on its rear axle is cockeyed- it's supposed to point straight ahead- but I wasn't thinking ahead at that point and I didn't correct the alignment.
Here's what it all looks like now:
The front axle rotor assemblies are engineered to allow the builder to pose the front wheels, but the tie rod is to be glued in place rendering the wheels in a fixed position. I wanted to take advantage of what I thought was some cool engineering, so I drilled out holes in the tie rod ends (destroying the hex nut detail) as well as the mounting points on the back of the rotors and inserted wire pins. The wheels will now turn left and right; the pin locations are circled....faintly (sorry)....in yellow:
Here's the attached front axle, and the whole chassis/suspension to this point. Only a few minor bits remain to complete this assembly:
I added the plug on top of the winch motor. Yes, it's a tiny white square bit on top of a round disc:
The engine spark plug wiring is complete. The copper wire I began with gave me a bit of a hard time so I used 10 lb. fishing line for the other five wires. The fishing line was much more cooperative. I couldn't find clear pictures of how these wires ran from the distributor to their respective spark plugs so I'm going to employ a little creative gizmology: I'm going to wrap the middle of the bundle in a bit of discarded white curtain material and call this an asbestos wrap as some wires are laying right across the valve cover and block. The mesh in the curtain is very fine so I think I can pull it off.
Finally here's the main cab body and the firewall area. The seats I covered with.....umm, 'tissue' paper to represent canvas, and the levers between the seats are, driver to passenger, transfer case shift, declutching lever (front axle engage/disengage), handbrake, and Power Take Off. The firewall unit has the gas, brake, and clutch pedals attached, as well as the PE part on top which represents a closed cab fresh air vent.
The round brake and clutch pedals came as smooth discs, but the real things have circular grooves. I used a drafting stylus to cut grooves in my pedals, which I had temporarily fixed to the end of a dowel:
That's all for now. Thanks for looking in; comments/critique welcomed.
Dave
    May 2009
Posted by Pawel on Tuesday, March 11, 2014 3:32 AM
Hello Dave!
That's a very nice looking machine you got there! I like the undercarriage a lot. For thicker wires and for rubber hoses - try to get some thin soldering wire, that's great stuff and looks very nice like rubber once painted dark grey. Good luck with your project and have a nice day
Paweł
www.vietnam.net.pl
Posted by HeavyArty on Tuesday, March 11, 2014 5:13 AM
Looking pretty good.  The spark plug wires do not run like that though.  The wires are enclosed in the tube that runs down the center of the valve cover.  Then each wire comes out of a hole above each spark plug.
Also, check out this site for some great rebuild pics:  http://hmvf.co.uk/forumvb/showthread.php?9939-the-restoration-begins-on-the-969A
    February 2010
Posted by Stage_Left on Tuesday, March 11, 2014 7:16 PM
Pawel- thank you for the compliment! Thank you also for the tip about the solder; I've seen it used for the applications you mention and I agree it looks good.
Gino- thank you VERY much for those pics! That's exactly what I'd been looking for. I'd spent at least an hour and a half searching for images of that motor before I launched into my wiring frenzy, but google failed me. The rebuild log from that forum is a treasure trove of info. Sooo......off for a redo. Thanks again Gino Yes
I appreciate you taking the time guys!
Dave
    February 2014
Posted by USMC6094 on Thursday, March 13, 2014 5:35 PM
Good LORD man thats insane. Your build is coming right along, and well, but it looks like that chassis is gonna be a mother to paint with all those different angles on all the parts.
Still thats a mighty fine looking wrecker so far
    January 2006
Posted by SprueOne on Friday, March 14, 2014 2:16 PM
Following this build for sure. I just bought this kit recently right off of a hobby shop shelf in Vegas. As described, a lt of parts in that heavy box.
Very helpful link and images, Gino
Anyone with a good car don't need to be justified - Hazel Motes
Iron Rails 2015 by Wayne Cassell Weekend Madness sprueone
    February 2010
Posted by Stage_Left on Friday, March 14, 2014 4:01 PM
USMC6094- thank you for looking in and your comment. I plan to paint the chassis, cab, and body/boom equipment as separate subassemblies, at least with the base coat, so that'll allow for better coverage.
SprueOne- thank you for looking as well. Yeah, once you open that box it's something, huh? Please put some pics up when you start your build.
Dave
    July 2006
Posted by bufflehead on Friday, March 14, 2014 11:03 PM
Dave, I've done a couple of all resin kits before and they can be a bear!  Looks like you've got this one under control, although that undercarriage looks insane!!  Nice work!  Keep the updates coming!
Ernest
Last Armor Build - 1/35 Dragon M-26A1, 1/35 Emhar Mk.IV Female
Last Aircraft Builds - Hobby Boss 1/72 F4F Wildcat & FW-190A8
    February 2010
Posted by Stage_Left on Saturday, March 15, 2014 10:15 AM
Ernest- thanks for dropping by and the compliment! The resin kits you did: are you referring to the Accurate Armour Diamond T wreckers? I know they had both the soft top and hard top versions available, but I haven't seen them as available in their catalogue recently and, at over $200 with shipping they were prohibitive for me anyway. I was thrilled when Mirror Models stepped up!
Yeah the undercarriage is a bit tedious; each component is a separate piece, but when done it does look the part! More progress soon......
Dave
    March 2004
Posted by subfixer on Saturday, March 15, 2014 10:17 AM
Dave, great job so far, I also am a sucker for support vehicles,
This is a styrene kit, isn't it?
I'm from the government and I'm here to help.
    February 2010
Posted by Stage_Left on Saturday, March 15, 2014 10:28 AM
Thanks subfixer- much appreciated! Yes, this is all styrene with a small fret of PE, some chain and a length of thread for the cables.
Dave
    March 2004
Posted by subfixer on Saturday, March 15, 2014 12:15 PM
There just might be one of these in my future, thanks!
    February 2010
Posted by Stage_Left on Thursday, March 20, 2014 12:54 PM
subfixer
Ah cool, glad I could help shed some light! As I've said I really like this kit, just be aware that there's cleanup on EVERY SINGLE part due to the large sprue gates. The mold lines and ejector pin marks are almost non-existent. Anyway, a little more update. I've corrected the spark plug wiring, and added a water pump feed line (blue wire) and a coil seen behind the blue wire in pic #2 and identified with a red circle and arrow in pic #5. Thanks again to Gino for the link to that awesome rebuild log on a real Diamond T 969 wrecker!
Just a note to anyone considering adding the spark plug wiring: it's much easier to accomplish this before installing the coolant return line on top of the valve covers, part C10.
I've also carefully thinned out the side hood cooling louvers with a sharp blade on the part on the left, and what they look like before thinning on the right.
That's it for now; comments/critique welcomed and thanks for looking.
Dave
    May 2009
Posted by Pawel on Thursday, March 20, 2014 1:22 PM
Hello!
Nice job on re-doing the wiring, Dave! Ain't it a funny feeleing when reference pops up a little late? Respect to you for ditching your first try and doing it again, right. I look forward to next updates, good luck and have a nice day
Paweł
www.vietnam.net.pl
Posted by HeavyArty on Thursday, March 20, 2014 1:46 PM
Very nice.  The wiring looks great.
    February 2010
Posted by Stage_Left on Thursday, March 20, 2014 6:09 PM
Pawel- thanks for following and for the nice words! I'll call it a lesson on the evils of impatience; I had a feeling I should have asked when I couldn't find the references I wanted but that instant gratification of plowing ahead was apparently too tempting Devil
Gino- thank you again Yes
Dave
    December 2008
Posted by New Hampshire on Sunday, March 23, 2014 8:42 AM
Hey, this looks like a cool project.  Certainly something you don't see everyday, and if there is one thing I love most of all it is the more obscure and lesser known stuff.  Tigers, Panthers, Shermans and T-34's all are fun and have their place, but it is vehicles like this that make for more fun building and watching be built. CoolYes
Brian
    January 2006
Posted by SprueOne on Sunday, March 23, 2014 3:37 PM
nice recovery on the re-wiring part Yes
    February 2010
Posted by Stage_Left on Sunday, March 23, 2014 8:01 PM
Brian- thanks for the look and for the comment, I do appreciate it! I agree with your sentiment, and I'm admittedly a big Tiger fan myself, but I've got a healthy selection of 'other' stuff in the stash: Testors/Italeri M32 (one of the coolest things I'd ever seen when I built it the first time in junior high), Tasca M32, AFV Club M88, and Tamiya M26 among others. I'm looking forward to getting them on the bench, all in good time.
Thanks again SprueOne!
Dave
    July 2006
Posted by bufflehead on Sunday, March 23, 2014 9:52 PM
Stage_Left
Dave
Sorry Dave, I must have missed your response!  No, I haven't done any Accurate Armour resin kits, just one from Coree and a couple of 1/72 kits by an obscure mfg!!
BTW, great job with the engine plumbing!!
Ernest
    March 2014
Posted by Slow-builder on Saturday, March 29, 2014 6:48 PM
Dave,
I just found your build, great work.  I'm also in the middle of my own Diamond T build, just a bit behind you.  Parts clean up has been a real pain.  So far nothing broken or lost.  After spending a lot time getting the drive train to fit I think a better sequence would have been to start in the middle and align the axles after installing the drive staffs.  What do you think?  Also I found that slightly drilling the universals allow the drive staffs too stay in place without glue.
How did you thin the louvers?  I'm at that point on my build and would like to give it a try.  What is your plan on displaying the engine detail?  I had thought to keep the  hood closed and as not going too wire the engine.
On the wheels I ran a knife blade around the rim for additional definition.  Also I noticed in the Squadron reference some of the photos of the tires show a center seam so I was not worried about completely removing the seam.  Do you agree?
Keep up the great work.
Russ
    February 2010
Posted by Stage_Left on Monday, March 31, 2014 12:45 PM
Hi Ernest- I did a quick search on Coree and they seem to focus on figures? In any event you're certainly ahead of me in that I've yet to tackle my first resin kit. Thank you for the comment on the engine work.
Russ- you and I could share the same handle, slow builder, although I've been really grinding on this one to keep the progress going.
I'm glad to hear you're also building this kit. Your approach to install the drive shafts and then align the axles sounds like a good way to avoid having to work around and behind the axles. I also like your idea to drill the universals to keep them in place without glue- sounds like a neat alternative. In any event though I would definitely recommend lots of dry fitting to allow each builder to come up with their own best method for installing this complex assembly.
I thinned the louvers with a combination of xacto #11 and #16 (scoring) blades and good old fashioned patience and care. The scoring blades have a bigger angle and thus don't easily protrude as far into the louver openings, helping to avoid scraping the back end of the opening. It's just a simple process of repeated passes, and I often use the back edge of the blade to avoid gouging the plastic. Tedious and time consuming? Yes. Better looking and worth the effort? I think so.
To be able to see the engine I've decided to thin down the left and right hood panels and not permanently attach them. At this point I'm not sure I want to glue them in the open position; I'm still considering this aspect and I'd definitely entertain ideas. I suppose obtaining a length of syringe from a medical supply or other such site and running a very thin wire through that would fashion a workable hinge for each side, gluing half the length, say, of each side to the hood panel and the other half to the brace on top to which the hood panels attach. Just ideas, so we'll see. I found myself down this particular rabbit hole because I decided I couldn't just cover up the beautiful engine detail, especially the spark plugs.
On the rear wheel rims the gap that was created by the wheel/tire halves was too much for me so I filled it in. I see that there is a seam where the back half of the rim overlaps and is riveted onto the front half, but I decided to not fuss over this detail (hmm..... Huh? ). I noticed the same tire seam as you; this would make sense to me with new tires. I wanted to represent mine as having some wear so I added a little filler as necessary and sanded down.
Anyway, thank you for weighing in and your encouragement. I welcome your thoughts as you progress, especially since we're roughly at the same stage in the build. My goal is to complete the cab, body, and chassis/suspension, then base coat as subassemblies before putting it all together for final finishes. I'm currently finishing the mast assembly that anchors the boom equipment. If you haven't reached this point, use caution as proper alignment can be tricky. On second thought, maybe you've already figured that out about this kit Wink
Thanks again for stopping by guys!
Dave
    March 2014
Posted by Slow-builder on Tuesday, April 1, 2014 12:15 PM
Dave,
Thanks for the info.  I think hinging the hood is beyond what I want to try.  If you do go ahead with hinging a source for very fine tubing is "Ngineering" they have tubing down to .018 inches.  You can get the tubing directly from them or from Walthers.com model train supply.
I have put a base coat on the chassis/suspension and engine.  I'll get the cab/hood done next.  Then I can do another base coat to get the inner braces on the fenders.  Then I'll mount the wheels.  I expect to mount the front wheels first and then one set of the rears.  I'll adjust the second set of the rears to get all wheels on the ground.  Any opinion on which set of the rears to mount first?  I find the tiny locating pins almost useless and the holes always need to be cleaned out.
