Three SKIF T-55 variant tanks - WIP to Finish
    January 2006
Posted by SprueOne on Sunday, March 2, 2014 1:30 PM
I've read a lot about SKIF T-55 kits and know they aren't accurate or detailed correctly. SKIF is the only company that made these three variants in plastic so I couldn't pass these up.
They'll be OOB without AM products included.
A group build on another site motivated me to start these and I have until May to complete Cool
I started with the lower hulls and they all fit poorly but that's what putty is for
This also dictates that they'll be strictly Curb Side models Wink
34 more sets to go if you include the idlers Indifferent
Tags: BUBLINA , FAVORIT , SKIF , SLA , T-55
Anyone with a good car don't need to be justified - Hazel Motes
Iron Rails 2015 by Wayne Cassell Weekend Madness sprueone
    March 2005
Posted by Devil Dawg on Sunday, March 2, 2014 9:37 PM
That's pretty slick, Sprue! Great idea. I'll have to try that on my next tank build.
Devil Dawg
On The Bench: Tamiya 1/32nd Mitsubishi A6M5 Model 52 Zeke For Japanese Group Build
Build one at a time? Hah! That'll be the day!!
    July 2004
Posted by stikpusher on Sunday, March 2, 2014 9:49 PM
CHEATER!!!!! Don't you know that there are no power tools allowed for that sort of clean up work?!
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    January 2006
Posted by SprueOne on Sunday, March 2, 2014 9:59 PM
Haha thanks for looking in fellas
    January 2006
Posted by SprueOne on Monday, March 3, 2014 8:20 PM
The SLA APC has unique wheels and drive sprocket to the other two kits which require modification to the differential housing.
Then some filing and removal of various suggested details for each kit.
Thanks for looking in ...
Posted by Gamera on Tuesday, March 4, 2014 9:41 AM
Very cool! It's always great to see something a little different here. Yes
    January 2006
Posted by SprueOne on Tuesday, March 4, 2014 7:16 PM
Thanks for checkin in.
The odd ball subject matter of the box art is what grabbed my attention Geeked
    January 2006
Posted by SprueOne on Saturday, March 15, 2014 1:08 PM
progress continues ...
The lower hulls are 5 parts and the upper hulls are 1 piece including the fenders.
Thanks for looking...
Tags: SKIF
    January 2006
Posted by SprueOne on Sunday, March 23, 2014 3:33 PM
The SLA APC-55 hub caps. Filed off the plastic bolt heads to replace with PE.
Now a six bolt pattern.
Tags: SLA
    July 2006
Posted by bufflehead on Sunday, March 23, 2014 9:43 PM
Looking good Sprue!  I like that you're doing all three at the same time!  Should be real interesting to see how different each one looks when done!
Ernest
Last Armor Build - 1/35 Dragon M-26A1, 1/35 Emhar Mk.IV Female
Last Aircraft Builds - Hobby Boss 1/72 F4F Wildcat & FW-190A8
    January 2006
Posted by SprueOne on Monday, March 24, 2014 9:11 PM
Thanks for checkin' in.
Building all three at the same time was the only way I thought I can get them done. If I started and completed one at a time then it would be like starting all over again and again and again.
That would probably discourage me mentally.
    January 2006
Posted by SprueOne on Wednesday, March 26, 2014 9:41 PM
One of the fender fuel tanks on the T-55C1 BUBLINA was a short-shot cast. The plastic didn't get all the way into all the corners of the mold on some of the sprues. This part was one of them.
I first tried to make a quick aluminum foil form to melt/cast a new upper part of this fuel tank by melting some sprue chips from this kit.
 = Fail thumbs down
NEXT:
Try using foil again to make a partial patch, then fill in the back with glue and material.
 = FAIL thumbs down because it still leaves an un-sandable layer.
Finally I use silicone gasket material in a tube to make a quick and inexpensive mold:
Then cast with casting resin. This worked and with a little putty and sanding will look fine.
The rear lower hull part was also "skinny" on one of the spare track studs. I snipped off the parts I need from the SLA APC-55 kit to repair the BUBLINA. The i-sheets in the SLA kit says to file off and remove these anyway so it was perfect idea
Thanks for looking . . .
Tags: SKIF
    January 2006
Posted by SprueOne on Saturday, March 29, 2014 10:46 PM
FAVORIT upper hull warpidge and solution
Moving right along and thanks for looking...
Tags: SKIF
    July 2006
Posted by bufflehead on Saturday, March 29, 2014 11:01 PM
I like your fixits Sprue, especially with the fuel tanks!  Classic!!
Ernest
    January 2006
Posted by SprueOne on Sunday, March 30, 2014 6:28 PM
Thanks Beer
    January 2006
Posted by SprueOne on Tuesday, April 8, 2014 10:50 PM
The head light brush guard is kit supplied PE and is square instead of tubular material. Very fragile and requires careful clean up. The iSheet provides exact size description. I used basic geometry to make a balsa wood form to bend the PE part around.
The fender support PE is identified in the iSheets for specific positions on the kit hull fenders. These were measured and lightly scribed so I could glue them on top of each marked position.
Thanks for looking Smile
Tags: SKIF
Posted by Gamera on Friday, April 11, 2014 11:15 AM
Very clever idea there to repair the fuel tanks and get the right bends in the light guards!
    January 2006
Posted by SprueOne on Friday, April 11, 2014 10:37 PM
Thanks.
The silicone gasket material had to be applied in thin layers because it's air dry.
    August 2006
Posted by Gun Tech on Sunday, April 13, 2014 12:35 AM
This is great stuff Sprue!
Nice to see that you do not get discouraged with the kit's issues and seeing you bashing along!
Beauty!
Yes
I really liked the foil idea, I might have to see if I can refine it and make it work......
Jean-Michel    "Arte et Marte"
    April 2005
Posted by JohanT on Sunday, April 13, 2014 2:39 AM
Saving the drawing for the birdcage for future reference :)
XLNT, thank you for sharing Sprue!
Very Best Regards
Johan
    January 2006
Posted by SprueOne on Sunday, April 13, 2014 3:24 PM
Gun Tech and JohanT, thanks for checking in and commenting Cool
I drew the blue lines though the inside dimensions of their provided drawing. While these kits aren't accurate, the SKIF assembly design is well thought out
    January 2006
Posted by SprueOne on Monday, April 14, 2014 8:55 PM
 The turret is a simple structure. The turret parts sprue is a different color green and a different plastic.
Some major gappidge needed filling with putty and the kit iSheets describe metal parts included for making grab handles for the sides of the turret.
My kit did not include this material. I made my own with stretched sprue Idea
 T-55 FAVORIT sprueone
Puttied the gappidge.
Nicely molded in weld seam detail on top.
Dimensions for the grab handles were found by web searching 1/1 and then comparing this to the model part. A satisfactory conclusion was derived.
marked right and left side for drilling
sprueone
Tags: SKIF , FAVORIT
    July 2006
Posted by bufflehead on Tuesday, April 15, 2014 11:00 PM
These are coming along great Sprue!  Love all the work arounds for the details!  Some very nice PE work as well!
Ernest
    January 2006
Posted by SprueOne on Wednesday, April 16, 2014 8:38 PM
Thank you for checking in and you kind words.
I'm finishing the PE on the hull and infrared light on the turret then I'll prime and paint by this weekend … hopefully Big Smile
Posted by Gamera on Thursday, April 17, 2014 10:34 AM
Cool, looking forward to seeing some paint slapped on.
    January 2006
Posted by SprueOne on Sunday, April 20, 2014 6:36 PM
Thanks, the FAVORIT is almost there.
Perfect weather today so primer goes on today then maybe a base coat color.
Thanks for looking.
Tags: FAVORIT
    July 2003
  • From: On my kitchen counter top somewhere in North Carolina.
Posted by disastermaster on Monday, April 21, 2014 3:05 AM
Great handling of that sprue!
http://www.leasingnews.org/items/roping.gif
Goes right with the name........ SPRUEONE.
I like that.
Sherman-Jumbo-1945
"I was so much older then, I'm younger than that now"
    January 2006
Posted by SprueOne on Monday, April 21, 2014 5:57 PM
Thanks for the comment Cool
    July 2006
Posted by bufflehead on Tuesday, April 22, 2014 11:46 PM
You're spruecing this one up nicely Sprue!!
Sorry, after Steve's comments I couldnt' resist! Stick out tongue
Ernest
    January 2006
Posted by SprueOne on Wednesday, April 23, 2014 9:31 PM
Haha, that's cool Big Smile
It's under a green base coat now and still working on the BUBLINA and the SLAPC
