question on marder III muzzlebreak
    December 2003
Posted by spector822002 on Saturday, February 28, 2004 1:13 AM
Is the muzzlebreak on the new tamiya kit accurate ? I just got a Jordi barrel and the break is different ( I put little faith in jordi rubio being accurate)
    July 2003
Posted by lizardqing on Saturday, February 28, 2004 1:28 AM
I noticed the same thing on the one I am building right now. The one on the Jordi barrel is alot smaller than the Tamiya version. You also have to figure out the right placement for the Jordi one since it has no tab like the Tamiya one. As far as accuracy, I have no clue. But it may as well be on mine since it is glued nice and tight.
Posted by Anonymous on Saturday, February 28, 2004 1:49 AM
I just checked two different sources, and for 1/35th scale, the muzzle break should be about 14mm X 9mm. I checked my Tamiya Marder III with the 7.62 Pak 36, and the dimensions appear to be correct for that kit.
hope this helpsBig Smile [:D]
    December 2003
Posted by spector822002 on Saturday, February 28, 2004 8:26 AM
TY edog , I just noticed a different shape on the 2 barrels , however I did notice on the different pix I had of the real gun , there were some of each style of MB on the guns , so maybe its just another case of right if you use either ?!
