ANTI-TANK GUNS
    July 2003
ANTI-TANK GUNS
Posted by diggeraone on Saturday, February 28, 2004 6:41 PM
Do any of you know if there are any anti-tank guns made by who?and if there are others than what I have found with TAMIYA.?DiggerSmile [:)]Cowboy [C):-)]Smile [:)]
Put all your trust in the Lord,do not put confidence in man.PSALM 118:8 We are in the buisness to do the impossible..G.S.Patton
Posted by tigerman on Saturday, February 28, 2004 6:52 PM
Not much out there. Dragon makes a 50 mm Pak 38. Italeri is releasing one later. AFV makes a 88 mm Pak 43 and is releasing a 75 mm Pak 40 (drool) in April.
 Eric
Posted by Anonymous on Saturday, February 28, 2004 7:17 PM
Here's a few kits ' In-Stock' currently at GreatModels!
1/35 th Scale:
ADV/Azimuth 88mm PAK 43 L/71
ADV/Azimuth 12.8cm PAK 81/1
Dragon 7.5cm PAK 97/38
DML/Dragon 3.7cm PAK 36 w/crew
Gunze Sangyo PAK 38
Tamiya PAK 37mm 35/36
Tamiya PAK 75mm 40/L46
AFV Club 88mm PAK 43/41
Prices range from $108.00 to $6.00. You can go to GreatModels at:
www.greatmodels.com
HTH!
Glenn
P.S.- I started building armor about 1 year ago. I started by building the Tamiya 37mm Pak kit. An easy start. Then tried the Dragon 7.5cm Pak. It's a good kit too!
Posted by Rob Gronovius on Saturday, February 28, 2004 7:31 PM
I will make the assumption you are talking about towed artillery in 1/35 scale. Here are some more that I have and did not see the other two gentlemen post about.
Italeri US 57mm anti-tank gun currently under release by Zvezda as the Mk-I 6 pound anti-tank gun (#3518).
Warriors makes a US 3" anti-tank gun conversion for the Italeri M101 105mm howitzer (#319).
Italeri Zis-3 (M-42) 76.2mm Soviet anti-tank gun (#302).
Italeri German PAK 40 anti-tank gun (#318).
Not a comprehensive list, just what I happen to own.
Posted by Anonymous on Saturday, February 28, 2004 7:34 PM
Tamiya do a 6 pounder
Accurate armour make a 17 pounder
Italeri do some of the Russian AT guns but i think there re boxed russian kits
Cromwell models do a 88 Flak 41 but it was used alot as a Pak
Posted by Anonymous on Monday, March 1, 2004 3:41 AM
verlinden makes an 88mm in 120 scale i wish there was more of them
Tamiya maker the 25 pounder
italeri
6425 PAK 38
6429 DUKW with 105 mm Howitzer
324 Nebelwerfer
355 Steyr RSO with PAK-40
358 Panzerjäger I with 4,7 PAK
363 Flak 43
