Dragon 1/35 Hummel WIP
    March 2014
Posted by Tarasdad on Thursday, July 24, 2014 10:44 PM
Since my USS Arizona build is sidelined by paint issues I decided to get a start on my Dragon 1/35 Sd.Kfz.165 Hummel Late Production kit. This is my first Dragon kit and I must say I am simply amazed at the detail! Some of the parts on the trees are so tiny I have to use my Optivisor to tell if they're parts or flash!
Here's what I've done so far:
The wheels still need to have the seams removed - all 20 road wheel pairs in particular, whee! I'm debating whether to leave the driver's vision ports open or go ahead and close them. There's no interior detail for the driver's compartment, not that you could see much through the tiny ports, but the visors do use a bit of photo-etch that would otherwise go to waste.
I'm currently working on the gun assembly. Pics when it's done.
Tarasdad
On the Bench:
  • Revell 1/48 F-15 Strike Eagle
  • Revell 1/48 A-10 Warthog
  • Revell 1/426 USS Arizona
    March 2014
Posted by Tarasdad on Friday, July 25, 2014 12:40 AM
Started working on the gun:
37 parts and counting!
Tarasdad
On the Bench:
Posted by tigerman on Friday, July 25, 2014 1:26 AM
Off to a good start. I have this in the stash, so I will be watching.
 Eric
Posted by Bish on Friday, July 25, 2014 1:57 AM
Nice start. I haven't got a Hummel gun version yet, being eyeing up this one.
    March 2014
Posted by Tarasdad on Sunday, July 27, 2014 6:48 PM
Finally managed a bit more progress.
Fighting compartment
First bit of photo-etch - 45 minutes to fold this!
There's still a long way to go. I haven't even thought about the tracks yet - 144 links per side provided although 13 links go on the front of the hull. Still a lot of photo-etch as well. Only mangled one piece so far, not bad considering the delicacy of some of the pieces and my lack of a proper bending tool. This is also my first time using photo-etch so it really is a learning experience.
Tarasdad
On the Bench:
    July 2004
Posted by wbill76 on Monday, July 28, 2014 1:46 PM
Looks like you're making good progress on this one! Dragon's most recent Hummel kits are nicely detailed. Just a side note, you don't need to use all of the links provided to create the track runs per side. 144 will be way too many, you'll only need about 108-110 or so depending on the sag you want to create (that count is just an estimate by the way, not a precise recommendation). Dragon always provides 'extra' links both for the spare track runs like the 13 you mention but also as spares in case you need them for whatever reason when it comes to building the tracks. Wink
    July 2008
Posted by castelnuovo on Monday, July 28, 2014 6:07 PM
I built this few years ago...a challenging little bugger with some 1000 parts.
    March 2014
Posted by Tarasdad on Saturday, August 9, 2014 5:29 PM
Decided to do some more work on the Hummel while dealing with a paint disaster on the Arizona. Pretty sure it's just about ready for paint, really only need to do the tracks first.
Progress to date:
Here are the paints I will use for the camo job:
Model Master Acryl over Tamiya primer. I'm starting to really like these paints.
Tarasdad
On the Bench:
    July 2004
Posted by wbill76 on Sunday, August 10, 2014 3:41 PM
Looks like you're all set to have paint fly on this one, looking forward to it. Beer
    March 2014
Posted by Tarasdad on Wednesday, August 13, 2014 9:45 PM
Weather here finally cleared up enough to be a bit more arthritis friendly (jut hot instead of hot and humid) so I decided to tackle the last bit of construction prior to painting: Magic Tracks.
Just the left one done so far. Going to let the glue cure a bit more before I separate it and remove it for painting. While it's off I'll count links so I can match the right track to it for length.
Tarasdad
On the Bench:
Posted by T26E4 on Thursday, August 14, 2014 6:47 AM
Nice work on a complex model!  If I can share a tip with you regarding the PE work.  One of my essential tools is a narrow jaw, non-serrated locking hemostat.  You can find these at your local hobby shop (Squadron 10502 is one example).
It's useful in the following way:
Once I cut the PE part from its runner, I clamp the part in the hemostat jaws parallel with the edge that has the nub to be filed off.  Then I run my file along the edge and the nub comes off quickly and cleanly (never file perpendicular b/c you'd bend the part by mistake).
Once the nub is cleaned up, I adjust the PE part in the jaws so that any part that needs to be bent is right at the edge.  I'll then bend the part using a small screwdriver, my exacto or tweezers-- whatever is called for.  I can bend and manipulate the part again quickly for subsequent bends, if needed.
I can fly through many small PE parts now -- also know that you don't have to use all the PE. Often, its benefit does not outweigh the work nor is it even an improvement sometimes.  Plan judiciously.
And I can't stress good vision magnification & illumination -- it just enhances your dexterity with small & fine & fragile parts.  Good luck
Roy Chow
Join AMPS!
http://www.amps-armor.org
    March 2014
Posted by Tarasdad on Thursday, August 14, 2014 10:17 AM
Both tracks are done. Ended up being 103 links per side for a modest amount of sag. Only had one link disappear into the ether on me - not bad!
Tarasdad
On the Bench:
Posted by tigerman on Saturday, August 16, 2014 1:53 AM
Track sag looks excellent. Keep up the good work.
 Eric
Posted by Bish on Saturday, August 16, 2014 2:15 AM
Looking really good, and the track sag looks just right.
    March 2014
Posted by Tarasdad on Saturday, August 16, 2014 5:49 PM
Painting has begun!
Model Master Acryl Panzer Dunkelgelb over Tamiya Light Grey primer. Excellent coverage and finish, quite pleased! Now I just need to make up my mind which camo scheme to use. Been trying to decide since I started this kit and still can't!
Tarasdad
On the Bench:
    March 2014
Posted by Tarasdad on Saturday, August 16, 2014 8:51 PM
While debating camo I went ahead and painted the tracks:
Tamiya primer, Metalizer Steel (non-buffing), chocolate brown wash, rust wash, finally dry-brushed with steel. First time actually weathering German tracks! In the past I've always just painted them steel and left it at that.
Tarasdad
On the Bench:
    March 2014
Posted by Tarasdad on Monday, August 18, 2014 10:40 PM
Camouflage is done. Went with the scheme for a Hummel assigned to the 2nd SS Panzer Division "Das Reich" on the Eastern Front in 1944.
Still have a bit of touchup painting as well as decals and weathering to do.
Tarasdad
On the Bench:
    January 2013
Posted by jibber on Tuesday, August 19, 2014 7:01 AM
A lot of tough fitting parts on that Hummel, you've done a great job with it. Nice job on the gun and tracks too.
    March 2013
Posted by garzonh on Tuesday, August 19, 2014 7:25 AM
Looks very nice, Im building the same model on the GB, so Im very interested in see what color, scheme you will use.
It is looking very good, the tracks look real good with that metal finish.
    March 2014
Posted by Tarasdad on Sunday, August 24, 2014 1:25 AM
While I was painting some of the detail parts I had a bit of a disaster:
Managed to splash some Model Master Metalizer on the camo job. As you can see it did quite a number on the paint. At this point I'm debating whether to try and repair the damage or just go ahead and repaint the entire thing. Fortunately it looks like the tracks and lower hull weren't affected so they can be masked off. Whatever I decide will have to wait until our air conditioner is fixed.
Tarasdad
On the Bench:
    August 2014
Posted by hazegry1 on Sunday, August 24, 2014 11:44 AM
almost looks like weathering to me maybe go over it a bit with some wash and call it done.
Posted by T26E4 on Sunday, August 24, 2014 9:06 PM
Hey Tarasdad: I sent you a PM via the site's "conversations" function
Roy Chow
Join AMPS!
