I want to build a Panzer III
    May 2006
Posted by CarnivourousDonut on Thursday, September 4, 2014 8:29 AM
Suggestions on a nice 1/35th scale that won't break the bank?
Side note, I've seen some nice side armour on ebay in that photoetch material that I would like to apply to the Panzer III, what glue/technique do you use to attach it to the model?
Let's rattle the cage, crack the machine. Let 'em know who you are, shine to be seen.
Posted by Rob Gronovius on Thursday, September 4, 2014 8:54 AM
Whether you use resin zimmerit (Cavalier, Atak) or photoetched (Eduard, Verlinden, etc.) you have to use super glue to attach. Sometimes you can use plain Elmer's white glue to maneuver it into place and once it is, let a small amount of super glue flow between the metal and plastic to make the bond permanent. Use a small object like a pin, needle or similar item to apply the super glue.
As far as a kit, the Tamiya one is sweet. I picked one up at Hobby Lobby a while back using their 40% off coupon. Dragon makes several really good ones, but the older ones will be cheaper but not as good as their newer ones.
Posted by T26E4 on Thursday, September 4, 2014 9:04 AM
The PE side armor, in my opinion, is not worth the hassle of soldering (what it really takes to get it firm) nor the alternative of using super glue (which will break easily since you're talking about a complex Schurzen plates plus brackets).
It sounds like your first venture into PE.  I would NOT recommend you get a PE schruzen set for a Panzer III.  The nice thing about the PE schurzen is its thinness.  But alternatively, you should just get some 0.010" thick styrene sheet and make your own.  And you can affix it with glues you're already using.
Let me repeat: as a PE novice,  I would NOT recommend you get a PE schruzen set for a Panzer III!!!!
Roy Chow
Join AMPS!
http://www.amps-armor.org
Posted by Tojo72 on Thursday, September 4, 2014 9:08 AM
The Panzer III-N is the only one that had the Shurzen Armor on the sides.Dragon makes a couple,an older one #9015 and a newer one # 6474
    October 2008
Posted by P mitch on Thursday, September 4, 2014 9:23 AM
I'd always go for Dragon 6474 as its a better build than a Tamiya. I know Tamiya may be easier but you'll learn more with the Dragon. Cost wise I think the difference is worth it for the better quality of the Dragon
Phil
"If anybody ever tells you anything about an aeroplane which is so bloody complicated you can't understand it, take it from me: it's all balls." R J Mitchell
Posted by Rob Gronovius on Saturday, September 6, 2014 9:28 AM
I guess I read wrong about the PE side armor vs. PE zimmerit. I'd save the money and use it to buy a more expensive or better Panzer III. Average cost for a PE fret is $15; that's easily 75% of the cost of an older Dragon kit or almost have of one of their newer kits.
Since I recall you mentioning cost being a factor, I know there's a Panzer III fanatic that hangs out at Missing Lynx named Brian Tears. A couple years ago, he sent me a boxload of Panzer III stuff, enough to build a complete kit plus extras, for a whopping $20 delivered. He's often selling off Panzer III kits when a newer version comes out.
Posted by Bish on Saturday, September 6, 2014 9:35 AM
I built the Tamiya Pz III N a couple of months back and it was a very nice build. But if you really want the Schurzen and are new to PE, I would echo the Dragon kit. They usually have some PE parts in the kit so will also be a nice introduction.
    August 2014
Posted by lando452 on Sunday, September 7, 2014 6:09 PM
here is a Dragon Panzer 3 Ausf J imperial series I built, this kit does not come with a crew, I don't know how much they run for now as I bought this kit over 10 years ago but I really like it
http://i21.photobucket.com/albums/b274/luis452/E193DDF9-A33C-4050-B4A3-A552BEF4D597_zpss8wz0rvk.jpg http://i21.photobucket.com/albums/b274/luis452/B53C212F-4CF9-486A-8243-C22FA59885A4_zpsl0c3jpyx.jpg http://i21.photobucket.com/albums/b274/luis452/435307B6-1B32-41F6-9C0E-D35A0D7C470A_zpstmtynfdw.jpg http://i21.photobucket.com/albums/b274/luis452/0B59FA40-1A01-477B-B673-9C90D8832374_zpsxsgqsacq.jpg
    September 2012
Posted by Tankster on Friday, September 12, 2014 11:18 AM
The Tamiya Ausf. L is a good kit.  I'd recommend going with something from the Dragon line.  Much more better value for your $$.  I'd shop around and see what you can find on sale.  Ebay usually has some good deals as does DragonUSAOnline.com  as well and they have daily specials.
I just finished this little beauty yesterday...Cyber Hobby Panzer III L Tropical.
On The Bench: Dragon  1/35 Jagdtiger Henschel
On Deck: Dragon 1/35 Ferdinand
