I have done this kit. It is a fantastic build, but you need to replace the kit barrels with RB ones. Not only does it make it look better, but the barrels are the correct length!
The tracks are designed to work and once you get a system going then they can be done in an evening, then it's just painting, Use a clear plastic bag so that you don't loose any bits, but if you get it right you should have a complete sprue of tracks (sprue H) for the spares box.
There is a jig to help you build and it is a godsend!
The suspension will work. Take your time, don't panic.
Look to Mig Ammo for the correct paint colours.
I used Quickwheels' set for painting the road wheels. you can also do Meng's other two T-90 kits with the same set.
My camera was in for repair when I built this, so there's no photos of the build, I will Photograph it and put it on this thread Tomorrow.
This is a very well done and enjoyable bit of mean looking Russian kit from Meng. It looks good when finished and in the cabinet.
Meng BPMT -90 "Terminator" Rules for building.
1. Don't Panic!
2. Spend lots of time with the manual. Learn it and understand what you are going to do.
3. Please replace the gun barrels!
4 Paint as you go along. It's easier!
5. Don't Panic. Remember the manual!
6.Take care around the tracks. This is where you have to pay attention. Use the Jig - don't be foolish.
7. Broke a peg on a track link? Plenty of spares. Work carefully and take your time.
8. Walk away when you have to. Take a break. It's useful.
9. No shortcuts in this kit. By the book!
10. Dry fit everything at least twice.
11. The mine ploughs are a SOB to build. It is very easy to get things mixed up. I did and got them wrong. BUILD THESE WITH EXTREME CAUTION. Never do them when tired!
There! That should help. It's a great kit of an unusual subject which has set me on a path of doing lots of Russian vehicles. despite the part count you will find that it is all a really good fit and goes together very well. It's one to enjoy, but needs care and attention at certain points of the build.
James
