Beav,
the tracks in both my IV-D & my T-34/85 were short.
the ones on the T-34 i superglued the ends together and strtched them on the kit.
they are drum tight and not very realistic looking.
the ones on the IV-D, i stretched by hand before gluing the ends.
unfortunately for me, the IV-D was already mostly assembled
(but i had not done the tracks yet)
when i ran into the problem on the T-34.
knowing what i know now, i will test fit the tracks against the drive sproket & idler BEFORE assembling the hull.
if they are way too tight, i can look at shifting the ends in slightly when i put it together.
(that is, move the drive sprocket & the idler closer together w/ modifications)
the extra fraction of an inch would make a big difference.
if you are going to stretch the tracks, do it w/ caustion, and take a slow approach
using minimal force.
otherwise, you will break them somewhere.
ed.
