tank wall breach question
gjw
    February 2011
Posted by gjw on Wednesday, January 7, 2015 5:57 PM
Hi everyone. I was just wondering that if a KV8 was breaching a brick wall whether the barrel would be pointed outwards or the turret would swivel to point the gun backwards. I have found some conflicting sources. Any info on this would be great!
Posted by Rob Gronovius on Thursday, January 8, 2015 10:33 AM
I don't know about that version of tank, but if you were going to smash through something, you'd want the gun tube out of harm's way. In a modern tank, the recoil is what ejects the empty casing. If you use the tube as a punch to make a hole, you'd eject the unfired round onto the floor.
Posted by Bish on Thursday, January 8, 2015 11:14 AM
I will echo Rob. And apart from the recoil, you would not want something getting jammed in the end of the barrel or the barrel getting damaged.
Posted by T26E4 on Thursday, January 8, 2015 11:21 AM
May I ask why it's breaching a wall?  A wall to a building?  Great for propaganda but seriously dangerous in real life.  Easy to disable your tank.  Easy to dislodge your track.  If it's a building, very possible there's a cellar -- and you'll fall into that cellar.  Plus you'd get a pile of crap all over the top of your tank, jamming hatches and the turret traverse and the ventilation of your engine....
Stand off and let one of your fellow tanks blow the snot out of the wall with HE -- that's the sol'n.  The flame throwing KV8 was an extremely valuable weapon -- not to be randomly used like an old disposible pick up truck.
Roy Chow
Join AMPS!
http://www.amps-armor.org
Posted by Tojo72 on Thursday, January 8, 2015 11:25 AM
That going thru the wall stuff is pure hollywood.
gjw
    February 2011
Posted by gjw on Friday, January 9, 2015 6:18 PM
Its not so much a wall but rubble but I see your point. I was considering putting the tank on the Mannerheim line but thank you all for your in put.
Posted by T26E4 on Friday, January 9, 2015 7:54 PM
Off the top of my head, I don't recall there being that many built up areas in the Finnish-Soviet border areas of conflict.  Mostly burned out and abandoned Finnish huts.
Roy Chow
Join AMPS!
