- Member since
April 2006
Posted by waynec
on Monday, June 8, 2015 6:15 PM
see if there is a kit review. i learned quickly that the Italeri LVT tracks are tight and usually shear the idler drive shaft. knowing this i break the kit drive shaft off, make a bigger hole and add a thicker shaft, and CYA it to the hull. usually i put all the wheels on but the idler, hook the track around the drive sprocket and road wheels, slip the idler inside the track and stretch to attach the idler to the hull CYA and accelerator may be necessary but this has worked for me on 1/35 and OTS (1/72)
Никто не Забыт (No one is Forgotten) Ничто не Забыто (Nothing is Forgotten)
