Looking into Airbrushing
    December 2015
Posted by Rangatron on Sunday, December 27, 2015 6:17 PM
Hi
I am a Brush modeler and I am looking at moving over to Airbrushing
I have done a few tank models before that havent turned out great
I am completely new to it, I dont know the first thing about Airbrushes
Is the sequence in painting any different to brush painting? (In brush painting I spray a Tamiya primer than paint 2 coats of the main colour)
Can the Airbrush be used in any way for weathering?
How do I maintain/care for the Airbrush?
What is a air compressor can for?
If there is anything else I should know, please tell me
Thank you
Tamiya please produce these models: TOG II*, Bob Semple Tank, Renault FT-17, Black Prince, 1/350 HMS Vanguard and more British stuff! If anyone works Tamiya or can pass this on, please do so!
    April 2007
Posted by SMJmodeler on Monday, December 28, 2015 10:10 AM
Rangatron: The reply to your questions would be a mile long.  If you did a "search forums" you should find help.  FSM magazine has been doing a multi-month series on airbrushing that you'll find very helpful & informative.
I'll do a brief response though to get you rollin'.
Sequence: Same.  Primer and the finish coat(s)
Airbrush for weathering: Mostly just for dust effects.  There are ways to get streaking and other effects with an airbrush but it requires a lot of control.
Maintanence:  Specific by mfr.  It's CRITICAL to do this frequently & thoroughly.
Air Compressor can: It provides the air/ pressure for the brush to work. You'll want to buy a compressor.  I used a Campbell Hausfield from Wal Mart for years...about $50.00
Anything else:  Start with an inexpensive single-action airbrush.  Use acrylic paints, this is a personal preference but I use it because it cleans up easier and has less toxic fumes.  It takes a lot of time to learn paint ratios/ compressor settings/ brush control so PRACTICE, PRACTICE, PRACTICE!!!  Buy some inexpensive kits (old Tamiya kits build fast and are inexpensive) and have some fun!
When you get more experienced and comfortable you'll want to buy a double-action airbrush.
Hope that helps.
    January 2016
Posted by PanzerCommander on Sunday, January 3, 2016 7:59 PM
I use a CO2 tank..it doesn't cost that much to fill...and depending on use, will last a long time..
John McLaughlin
Posted by Tojo72 on Monday, January 4, 2016 2:39 PM
Google Don Wheeler's air brush tips,he gives a nice beginning airbrush tutorial.
I'm not saying to run out and buy a top of the line double action,but consider one like an Iwata,you can't go wrong.
    June 2015
Posted by OldGoat on Sunday, January 10, 2016 2:08 PM
Buy a double action and practise, practise, practise. You wont be disappointed.
    August 2014
Posted by goldhammer on Sunday, January 10, 2016 2:35 PM
I'll go with OG on the DA brush.  When you push down on the trigger you get air only, and the pull back releases paint from light mist to heavier coat.  Takes some getting used to if you have never had any kind of paint gun in your hand, but in the end it is worth it.  I have an Iwata Eclipse suction feed and I just got the Iwata NEO gravity feed and absolutely love it so far.  If you have a Hobby Lobby nearby, the NEO will run you about 50 bucks with the 40% off coupon.  You will want some kind of stand to hold itbetween coats, etc. and would recommend the quick disconnect fittings.
    July 2003
  • From: On my kitchen counter top somewhere in central North Carolina.
Posted by disastermaster on Sunday, January 10, 2016 7:26 PM
Tojo72
Here 'ya go...........https://yt3.ggpht.com/-T4GA0WxAqjY/AAAAAAAAAAI/AAAAAAAAAAA/JcqnDwL0EEU/s88-c-k-no/photo.jpg
(click TaDaa)
 https://i.imgur.com/LjRRaV1.png
    April 2006
Posted by waynec on Sunday, January 10, 2016 10:06 PM
OldGoat
i recommend you buy the airbush thinner for whatever paint(s) you use and same wuith the cleaner. it will cost a few bucks more but eliminates one variable when mixing. for exampleWindex works for most paints but i read it gums up aVallejo so i use Vallejo thinner and cleaner.
as for mix ratios get an old model with flat sides (JAGDPANTHER for me) and spray that first to see how the paint flows. take notes on drops of paint to drops of thinner so you know what works. for example i even thin Vallejo Air, 1 drop of thinner to 6 drops of paint works. or get some ComArt from Iwata which really is airbrush ready. i use it foir dinosaurs.
Никто не Забыт    (No one is Forgotten)
Ничто не Забыто  (Nothing is Forgotten)
Posted by waikong on Tuesday, January 19, 2016 10:09 AM
You know what, Airbrushing is a huge topic. Just search the web for some good pages, as mentioned before Don's website is very good and give great advise to answer most of your questions.
I will re-emphasize what many have said - practice.  Your first few or a dozen times you airbrush will be VERY frustrating.  Just be prepared, paint gets stuck (especially acrylic), too much paint goes all over the place, you spend more time cleaning and unclogging than painting your model.  Be prepared - but everytime you practice, it gets a little easier, and maybe you 12th or 24th (everyone is different) time, you seem to finally get the hang of it.  Practice on a left over kit first.  Good luck and show us your progress!
    March 2013
Posted by patrick206 on Tuesday, January 19, 2016 10:57 AM
Waikong and the others have great input, lot's of self study and reviews of airbrushes and airbrushing will pay off very well, when you do venture into the selection and purchasing step.
In addition to Don's Airbrush, and Snibs too, have a look at the reviews of airbrushes and their use on youtube, plenty of useful info there, to include handling, cleaning and maintenance, like taking them apart and reassembly.
I started with single action external mix, then to single action internal mix, then to dual action internal mix, both siphon and gravity fed. So many types out there, all the way from top line and expensive, to very capable but affordable ones.
My only recommendation is, don't buy more airbrush than you need. Purchase price will not determine performance, if you won't be doing any really fine detail work, a reasonably priced and capable airbrush can be had brand new for around $60-80.
I have been airbrushing for many decades, my first several attempts convinced me that either they could not be made to work, or I could not learn to use one. Finally, after dozens of attempts and failures the light began to come on, when the handling and care, paint thinning, pressure and such was correct, I found so much enjoyment and was rewarded with good model finishes.
Finally, as said so well by the others, three words of advice: Practice, practice, practice.
I wish you the best of luck in your research and the purchase. Let us know how you're doing, feel free to ask for any help we may give you.
Patrick
    September 2006
Posted by the Baron on Tuesday, January 19, 2016 12:57 PM
Yep, I'll second that--practice, practice, practice!
I use a Paasche VL, with a 1.5 hp Craftsman compressor with a 3-gallon tank.  The brush is a double-action, but I haven't quite yet gotten the hang of using that feature.
I have been getting good results with Tamiya's acrylics, especially once I learned to use their proprietary thinner with their paints.  They are formulated for airbrushing, and I tried water and isopropyl (separately) and neither thinned the paint as well as Tamiya's thinner.  I have tried lacquer thinner, too, and that worked pretty well, too.
I also use Model Master paints.  With enamels, I use mineral spirits, and with acrylics, I use isopropyl, and they have worked pretty well for me.
And I have used craft store acrylics, thinned with water.  They worked OK, but their pigments are rather coarse, and that impacted the final finish on the model.
When I use the airbrush, after I finish with one color, I do a quick cleaning, blowing more of the thinner through the brush till it comes out clean, and cleaning the cup and the neck from the cup into the brush.  When I am completely finished with a session, I break down the brush and clean it with lacquer thinner.  I have some fine brushes, about the diameter of pipe cleaners, that help in gently scrubbing the various opening and tubes.
But practice, and don't let mistakes get you down.  I've run into some hurdles, let myself get mad for a second or two, then sat down and thought it through and figured out the issue, learned the lesson and moved on.  A good one was forgetting to check that the nozzle was installed.  The brush blew air but no paint came out.  Finally, I started breaking down the brush and immediately saw it.  And boy, was my face red!
    December 2015
Posted by Dash8 on Tuesday, January 19, 2016 10:22 PM
For sure get an airbrush. They have really come
down in price. An airbrush finish will take your
model building to a whole new level. Like
everyone has mentioned it is not to hard
to learn it just takes practice. Also look at
getting a spray paint respirator to protect your
lungs NOT a dust mask. 3M makes great
ones that are not that expensive. This cockpit
dash hood was shot using Testors MMA semi gloss
black paint, you can see how smooth the paint goes
on with an airbrush.
On the bench: Revell Euro Fighter 1/32
Ontario, CANADA
    January 2013
Posted by Wood on Wednesday, January 20, 2016 8:22 AM
You will like gravity feed airbrushes better than siphon feed airbrushes once you learn how to use an airbrush. It's also better to use the paint brands paint thinner too. (EX) Tamiya paints use Tamiya paint thinner.
    June 2015
Posted by OldGoat on Wednesday, January 20, 2016 9:19 AM
Wood
^^What he said^^
Gravity fed AB's are easier to clean as well.
    September 2006
Posted by the Baron on Wednesday, January 20, 2016 12:02 PM
Oh, I don't know, I like my siphon-fed Paasche, as far as the paint flow goes.  I do just use the cup, though; I don't use the mixing jars and attachments.  But I'm really just a freshman, as far as experience goes, and still have much to learn.
My main issue with the brush is that I can't yet get really fine lines with it, and I suspect that I may have gotten as far as I can with it, on that particular item.
    April 2004
Posted by crockett on Wednesday, January 20, 2016 1:12 PM
the Baron
Paasche single action siphon feed.......FAIL
I did the same thing, when I got into airbrushing, bought the Paasche - IMHO = junk, and now I have a nice Iwata Micron, double action and can write with it like a pencil. My advice.....put the Paasche on Ebay and get a badger or Iwata double action....I promise you...life will be much better...
