Australian Centurion in Vietnam
    September 2014
Posted by Aussie modeller on Sunday, January 3, 2016 11:15 PM
G'day all,
this is my second build of Afv club's R.A.A.C. (royal australian armoured corps) centurion tank in Vietnam.
kit contents
this is a very good kit but in areas it, like any kit, needs some help from the aftermarket, I grabbed an update set from Firestorm models to get the ball rolling on my project.   but first, i will give a history lesson. in 1968, the army dispatched a squadron of centurion tanks for use over in Vietnam, after their first operation (operation pinaroo) it soon became apparent that a few things about the tank would have to change. First to go were the side skirts as they compacted mud and vegetation which would over-tension the tracks and sometimes break the idler wheels. another problem was that the fender mounted stowage bins would be distorted by the thick jungle which would also make them spill their contents out. but, us aussies being as inventive as we are, changed and adapted new solutions to these problems, we removed the side skirts and welded american "u" picket to the sides of the stowage boxes for added strength, we also added an infra-red searchlight that at night was mounted above the gun, and when not in use was stowed in the stowage basket. The Centurions were used in many ways from being utilised at fire support bases to finding and destroying bunker systems.
anyways, on with the project, I started with the suspension bogeys:
the bogeys are straightforeward to build and each has a metal spring to articulate them with. after they were out of the way, I made the roadwheels and replaced the kt supplied rubber tires with resin items form Firestorm which are a MUST imho. with those done, I built the basic block of the tank and the turret, I am making a mantlet cover out of thinly rolled milliput, which will be easy to make.
here the basic form of the tank is done, I replaced the glacis armoured plate with a resin item from Firestorm, but shaved off the bottom weld seams so that it would fit and replaced them with milliput.
that's al for now, any questions and comments are welcome
There's no such thing as a clean tank!
Posted by Bish on Monday, January 4, 2016 12:43 AM
Good to see some Aussie armour. Will be watching this.
    May 2009
Posted by Pawel on Monday, January 4, 2016 1:52 AM
G'day,
I just got one of those babies for Christmas, so I'm watching this, too! Could you write some more about those rubber road wheel tires? Good luck with your build and have a nice day
Paweł
www.vietnam.net.pl
    September 2014
Posted by Aussie modeller on Monday, January 4, 2016 2:57 AM
Pawel
G'day,
Paweł
g'day, i used them on my last one they are alright, but are loose-fitting and repel enamel
    April 2007
Posted by SMJmodeler on Monday, January 4, 2016 10:50 AM
Aussie modeller: Nice subject.  Thanks for the brief history lesson, it's good to have a little info at the beginning of a build.
You gotta' post some better pic's if you're looking for input.  The close-ups are very blurry.
Looking forward to seeing this one come together!
Posted by Gamera on Tuesday, January 5, 2016 7:47 AM
Always nice to see something a little different, very cool!
    September 2014
Posted by Aussie modeller on Wednesday, January 6, 2016 8:20 PM
SMJmodeler
sorry mate, my hands are very shaky at the moment, must be because I moved back to my old home town and am starting at a new school
thanks for the imput
    September 2014
Posted by Aussie modeller on Saturday, January 16, 2016 1:17 AM
sorry for the inactivity guys, haven't been doing much of my centurion lately as i have put it on the backburner for now, but have managed to do SOME work as i have been focusing on my tiger 1.
i went to melbourne and purchased some supplies,
i made the canvas mantlet cover out of white milliput rolled out thin and draped over the mantlet. i made the reinforcing staps out of said putty
i also stippled some mr surfacer 500 on the turret to get a cast metal texture.
i also stippled some of it on the glacis plate as this was also cast.
I then added some small details to the hull and turret.
here is the resin replacement long range fuel tank with kit parts attached;
and here is the resin stowage piece that i am using:
that's about it for now, i'll keep you guys posted
