Academy M1A1 - Complete
    February 2014
Posted by silentbob33 on Sunday, January 10, 2016 8:39 PM
Hi everyone,
My brother has been asking me to build an Abrams for him for quite some time, and I had the Academy kit in the stash for a few years so I figured there's no time like the present.  I'm not much of an armor modeler and I've read a few reviews of the kit and from what I've seen it's not too accurate.  That's fine because I'm not a rivet counter and neither is he.  Plus, this is a good chance for me to get in some practice with armor before I tackle the more complex armor kits in the stash.  Here's the box art:
I also found some decals for a Desert Storm tank from the 2nd Armored Division.
And here's where I am so far; the wheels are assembled, holes in the bottom hull are filled, and the back of the lower hull is together.  There is a hole in the back above the exhaust, I'll probably put a sheet of styrene in there to blank it out.
Unfortunately the instructions aren't all that great, and I'm not sure how these rings should look on the drive wheels, any suggestions?
Lastly, there are no clear pieces in this kit so I'll probably have to cut some out of clear plastic for all the hatches and viewports.
On my bench: Academy 1/35 UH-60L Black Hawk
Posted by HeavyArty on Sunday, January 10, 2016 9:05 PM
The worst part of the kit is the barrel.  It is way too short and hugely exagerated in its diameter, esp. the bore evacuator.  You should really get an AM barrel for it.  You need to look for an M256 barrel.  With the kit barrel it will look very toy-like.
By the way, there is no hyphen in the name.  It is simply an M1A1.
    February 2014
Posted by silentbob33 on Sunday, January 10, 2016 9:15 PM
Thanks for the heads up, I'll look into getting a barrel.
    September 2012
Posted by GMorrison on Sunday, January 10, 2016 9:21 PM
Don't bother with clear plastic. Fill the vision ports in with styrene and paint them black.
Posted by HeavyArty on Monday, January 11, 2016 8:54 AM
GMorrison
Agreed.  Then paint a couple coats of clear red and a couple coats of clear gloss over them and they will look like the correct anti-laser film coated optics that the real tank has.  The optics should not be clear.
    February 2014
Posted by silentbob33 on Monday, January 11, 2016 9:29 AM
Awesome, that sounds a lot easier. Thanks for the tip.
    May 2013
Posted by hogfanfs on Monday, January 11, 2016 9:34 AM
SB,
I'll be following along! Looking forward to this build!
And isn't it awesome having Gino around for all the technical information!
 Bruce
 On the bench:  1/48 Eduard MiG-21MF
                        1/35 Takom Merkava Mk.I
    February 2014
Posted by silentbob33 on Monday, January 11, 2016 6:05 PM
Glad to have you along Bruce! That's one thing I love about the forums, there are so many people here that are willing to share their knowledge. I can't begin to describe everything I've learned since I joined up.
Posted by Gamera on Tuesday, January 12, 2016 7:35 AM
Nice! So it might not be up to current standards but you've got the kit so you might as well build it while correcting the most obvious issues, thanks for letting us follow along.
    February 2014
Posted by silentbob33 on Tuesday, January 12, 2016 9:02 AM
Too true. I looked into getting an AM barrel and unfortunately it's not in the budget for now. I have the OIF Academy Abrams in the stash, so I'll save up and get it when I build that kit, and use this as a learning experience.
Posted by HeavyArty on Tuesday, January 12, 2016 11:21 AM
silentbob33
I looked into getting an AM barrel and unfortunately it's not in the budget for now. I have the OIF Academy Abrams in the stash, so I'll save up and get it when I build that kit...
Actually, in the "Iraq 2003" Academy kit, there is a new sprue that has a corrected barrel and a bunch of other updated parts that make it a pretty good kit in the end.  It is almost worth getting the kit for just the new "J" sprue, almost.  It still has the bigger problems of a too short turret (as all Academy Abrams do since the turret is a copy of Tamiya's original M1 kit and never corrected for an M1A1) and the old style T156 chevron-block tracks that have not been used since the early '90s.
    February 2014
Posted by silentbob33 on Tuesday, January 12, 2016 12:06 PM
Wow, good info there. Thanks. This is the third armor kit I've built, so I'm still a little outside my comfort zone.
    February 2014
Posted by silentbob33 on Tuesday, January 26, 2016 6:01 PM
Progress has been a little slow.  It seems like every little part has some kind of ejector pin mark on it.  It's a long processs getting them all filled in and sanded.  I have the turret just about done, all I really have to do is the basket along the sides and back.
These are the styrene blanks I put in for the optics.
Posted by HeavyArty on Tuesday, January 26, 2016 8:49 PM
Looking good so far.  The blanks on the optics look great.  One thing you may want to adjust is teh smoke launchers.  They should point up at about a 45 degree angle.
    February 2014
Posted by silentbob33 on Tuesday, January 26, 2016 9:05 PM
Thanks, I'll take care of that the next time I sit down at the bench. I thought they didn't look right when I put them on.
Posted by Gamera on Wednesday, January 27, 2016 7:55 AM
She's looking good Bob! I know what you mean about injection pin marks, AFV Club kits seem to be covered in them.
    February 2014
Posted by silentbob33 on Thursday, January 28, 2016 5:27 AM
Thanks! I can't believe how many there are. I sat down to get started on the turret basket and every part of except for three had several pin marks. So I had a short session of filling them and waiting for the putty to dry.
    February 2014
Posted by silentbob33 on Wednesday, February 3, 2016 8:55 PM
OK, finally some progress to show.  It was incredibly tedious filling and sanding all the ejector pin marks on almost every single piece of the brackets.  Each piece had between 2 and 4 marks.  I took a good look and I don't think I see any more on any of the other pieces.  I also attached the upper and lower hulls together.  I didn't bother filling in any blank areas since they won't be seen once everything is together.  Hopefully next week I'll be able to get some painting done.
    February 2014
Posted by silentbob33 on Friday, March 11, 2016 8:58 AM
Since I last posted I've gotten paint on the tank, wheels, and tracks.  I still need to do some drybrushing for the details though.  I also got some bits and bobs put on and gloss coated and applied decals.  This is taking me way too long.  Part of it is that I put off painting all those wheels and the tracks, it's way too repetitive for me.
Posted by Gamera on Friday, March 11, 2016 9:40 AM
Hey Bob, she's looking good!
And nice work on the tracks, I airbrushed a Sherman's treads years ago and then brush painted all the exposed metal bits. Never again! I've cheated and just airbrushed the whole blasted things with a muddy brown from that point on.
Btw: I paint my wheels dark rubber grey and then use a circle template from the art store to mask the wheels and spray the centers.
    February 2014
Posted by silentbob33 on Friday, March 11, 2016 9:45 AM
I don't know why I didn't think of that. I'll have to look for one the next time I'm out. Thanks for the tip.
    May 2013
Posted by hogfanfs on Friday, March 11, 2016 10:12 AM
SB,
Looking good! Coming together nicely! Looking forward to seeing this M1 finished.
 Bruce
    January 2016
Posted by Hunter on Friday, March 11, 2016 12:11 PM
Hey Bob -
Looking great sir, and I really like your idea for painting the rims. Using a circle stencil, great idea. I will be here watching and I hope you enjoy the build.
Hunter
    February 2014
Posted by silentbob33 on Thursday, March 17, 2016 8:08 PM
Thanks Hunter!
I did a pinwash and I really like how it turned out.  Unfortunately I ran out of dullcote and I won't be able to pick any up until after the weekend.  Barring anything unfortunate I should be done by the end of the month.
Posted by Gamera on Friday, March 18, 2016 7:56 AM
Cool Bob, hope we've lured you over to the 'dark side' to stay!
    February 2014
Posted by silentbob33 on Friday, March 18, 2016 8:49 AM
Gamera, I think it's pretty safe to say I've been seduced by the Dark Side. I have almost a dozen more armor kits in the stash and I keep seeing more I want to get...I'm going to need more display shelves.
Posted by HeavyArty on Friday, March 18, 2016 9:25 AM
Its looking good so far.  A couple pointers.  The 3/4 circle ring that the loader's M240 mount sits on should be steel (gunmetal) as well as it is unpainted to allow the mount to slide around on it.  Also, black paint in all the openings on the smoke grenade launchers makes them look better by giving the illusion of depth as the openings are actually the length of the launcher, not shallow as the part is molded.
    February 2014
Posted by silentbob33 on Friday, March 18, 2016 9:46 AM
Thanks for the pointers. After I posted the pictures last night I noticed on some of my reference pictures that the ring should be bare metal so I've already taken care of that. I'll be sure to take care of the smoke grenade launchers as well.
    February 2014
Posted by silentbob33 on Wednesday, March 23, 2016 8:05 PM
Well, she's done.  I didn't weather it too much because I built it for my brother and he wanted a pretty clean build.  I had an OK exerience with the kit.  Most parts fit together well enough except for the side skirts.  It was also really annoying filling the gazillion sink marks all over every small part.  Here is A-66 of the 3rd Battalion, 67th Armored Regiment, 2nd Armor Division in Operation Desert Storm.
This was a little bittersweet for me as this will be my last build until we are able to sell our current house and get moved into a bigger home.  I'll still be lurking around here until I can start building again.
    September 2013
Posted by Marcus McBean on Wednesday, March 23, 2016 8:28 PM
Very nice work.
