Working with soft plastic
    January 2016
Posted by Old Pappy on Friday, January 29, 2016 4:13 PM
I have started on an old Tamiya 1/25 Tiger I I picked up for a song ($10 USD!). It's fairly well-detailed for a kit of 1969 vintage, even if it's a fit-up nightmare (that's another thread). It has the snap-together track links, which I cannot replace with AM treads, for budgetary reasons, not to mention that I've heard that the kit-supplied sprockets won't fit the more accurate AM treads, anyhow. Thing is, the OOB treads are of some "soft plastic," the composition of which I do not know. Does anyone know what sort of plastic this is?
Some discreet experimentation has confirmed that none of the usual solvents/glues for polysty have any effect on this stuff. I'd like to do some filling and putty-ing, and don't have anything that will work. Nuthin sticks to this stuff; makes me wonder if it's some form of teflon or nylon or HDPE, or something.
Anybody got any idea what sort of plastic Tamiya was using circa 1969?
    May 2011
Posted by Real G on Saturday, January 30, 2016 3:28 AM
It might be polyethylene.  I had the 1/25 Cheiftain, and it had snap together track links like your Tiger.  The pads were separate and molded in black instead of metallic grey, and you were instructed to use the old hot screwdriver trick to secure them to the track links.  The plastic felt like poly cap material.
What do you need to fill/glue on the tracks?
“Ya ya ya, unicorn papoi!”
    July 2003
  • From: On my kitchen counter top somewhere in central North Carolina.
Posted by disastermaster on Saturday, January 30, 2016 8:58 AM
I built that back in '72.
I used the old tube glue (old formula).
It's still  sittin' pretty in the bookcase at present.
            http://msnsmileys.net/Y/Yolks/oo.png
Went by the instructions since there wasn't really
anywhere (other than the box top) that you could
find any info back then.
 https://i.imgur.com/LjRRaV1.png
    September 2009
Posted by Cobra 427 on Sunday, January 31, 2016 12:44 PM
Try using epoxy to glue, and Bondo body filler to smooth irregularities. I'd use the Bondo outside since it's so pungent.
Maybe a picture of a squirrel playing a harmonica will make you feel better?
    January 2016
Posted by Old Pappy on Sunday, January 31, 2016 7:04 PM
Real G
The plastic felt like poly cap material. What do you need to fill/glue on the tracks?
I does feel very similar to the poly caps. There are some spare treads at the front plate, which will be stowed with the guide horns and road wheel side out. There are numerous ejector pin marks and the molded track pins are visible on the inside, as well. I can live with it on the mounted treads, as I set out to build this largely OOB. But I'd like to clean up the stowed extras a bit, anyhow.
    January 2016
Posted by Old Pappy on Sunday, January 31, 2016 7:06 PM
disastermaster
Yeah, I tried that first. It dried overnight, and popped off cleanly the next day. No adhesion at all. Ditto for the liguid cement/MEK types.
    January 2016
Posted by Old Pappy on Sunday, January 31, 2016 7:09 PM
May hafta resort to that, Cobra. I was hoping to avoid the hassle of it.
