Tamiya 1/35 Leopard 1 Heavy IFV scratchbuild WIP
    February 2016
Posted by djizomdjinn on Thursday, March 10, 2016 8:14 AM
So, there was a pretty positive response to my first imaginary tank, so I thought I'd share the work in progress for the next one I'm working on right now.
Base kit is a Tamiya Kampfpanzer Leopard #35064 from 1969, so Scalemates tells me. I specifically chose this over the Leo 1A4 because I wanted the angled looking tracks, and I wasn't sure the new kit had them.
Anyways, the first thing is to mock up a plan that I almost certainly will not adhere to but I should make anyways. Tools of choice: cheap brown paper and masking tape.
Mock up of an up-armor package. Considering embedding magnets in the model so I can take them on and off.
Looks awful, doesn't it? Some scratchbuilders meticulously plan out every piece of their scratchbuild, draw it up in CAD, trace the bits on to styrene, and the whole thing falls together. I am nothing like that, which is probably why I like using the old Tamiya motorized kits, since they're not adverse to being manhandled a bit. That hull isn't going to stay in one piece, by the way, it's just a placeholder.
The final mock up of the interior layout. Mid-engine, as you can see, to make room for a troop compartment. Originally it was going to to be rear engine ala IDF Achzarit, but the wasted space and 105mm turret would have resulted in a staggeringly 3.8m tall vehicle. This layout drops it to about 3.3m. So Bradley tall, not Maus tall.
About where I am right now. As you've probably noticed by now, not a conventional turret. Cleft turret design with autoloader and all ammo stored in the bustle. Sad that they never really caught on; I'd love a model of the T92 Light Tank. Anyways, you'll notice a decidedly un-Leopard like bit of turret there. Well, I don't know whether it's coincidence, or some sort of US-German agreement, or whether Tamiya wanted to standardize their turret rings, but the M41 Walker Bulldog turret has about the same size ring as the Leopard model. Wrong polarity though (on the M41, the male flanges are on the hull, on the Leopard they're on the turret) so I had to make my own turret base. Also probably not putting magnets on the turret; the complex angles and curves there would make building add-on armor a nightmare. Probably far easier to build a brand new turret.
Also, just for fun:
Did someone say ~30 degree gun depression?
Posted by Gamera on Thursday, March 10, 2016 10:26 AM
That's pretty neat! And clever idea on mocking her up with card stock.
Looking forward to seeing how she comes out.
    June 2015
Posted by OldGoat on Thursday, March 10, 2016 10:37 AM
Looking good.
A couple of things, don't let the turret get too tall. Your vision would allow for a really low profile. That's a good thing in the tank world.
Cut the side armor in half width wise. What you show mocked up would make the tank way too wide. Protection can be accomplished with half of that. Look at a modern M1A2 with TUSK, or a Canadian Leopard.
Keep at it.
    February 2016
Posted by djizomdjinn on Tuesday, March 29, 2016 5:42 PM
Making some sensors out of pipe, styrene, and repurposed bits. From left to right, muzzle reference sensor, one of the Leopard's stereoscopic rangefinder blisters built up into a commander's independent sight, and something from the M41's turret roof built into a gunner's main sight.
Though, I might not end up using that L7 gun at all. Scratched up a 120mm I figured looked decently nice enough, and I might end up just using that instead. Also reprofiled the turret to add something worth being called armor. Unfortunately that means the turret is ending up about as big as the Leopard 1 turret, but oh well. Height over bore is superior except that a commander's cupola adds a lot of height to clear the gun and get 360 degree vision. I might just end up cutting the ring of vision blocks in half and giving half to each the commander and gunner.
I know it's easy to make up stats for a plastic panzer, but that could be 1.2+ meters of armor on the turret face right there, if I went with side-opening hatches near where the trunnions are. Also final tally for gun depression is "only" 22 degrees. Sure tanks can traverse 40% slopes, but this one could fight on them. Which is good, because the whole idea behind this tank is one optimized for fighting defensively on mountainous terrain. Where tanks generally don't excel.
Mocking up some blowout panels for the bustle ammo storage. Oddly, since the gun is offset in the turret, the shot lockers and thus the blowout panels are different sizes too.
Crew compartment, with a 1/35 figure, or most of one at least for scale. The idea behind the rails is to pull the tank power pack, you empty out the troop compartment, unbolt a section of the firewall, unbolt the engine, and the whole thing ideally slides out on rollers.
Been playing around with the idea of a self-entrenching dozer blade that folds under and becomes part of the lower armor plate, ala Strv 103. I mean, if the tank is designed to fight purely from a defensive posture, it makes sense to give it the ability to create it's own defensive positions, right...? On the other hand it's more front weight on an already very front-heavy vehicle, and visually it looks kind of funny as well. Maybe I'll save it for the add-on package.
