Well let’s see, it’s a Tam. T55, legend Tiran 5 resin set, Eduard PE, Verlinden dozer, MK tracks and some home brew odds and ends. When I was adding all of the IDF goodies I had to fill and sand all of the eastern block tie-down locating marks and that removed Tamiya’s beautiful casting marks on the turret so I used some Mr. Surfacer 500 and stippled it to get the finish of cast steel. Thanks for all of the kind words guys, all of you IDF gurus, I’m not sure I have the 60mm mortar mounted in the stored position right. Did the ball on the end of the tube go in the mount? Any help with that would be appreciated.
Thanks again guys.
Brian.
