One curiousity about it. In particular for a first time tank model.
The cover art shows the vehicle from the REAR, with the turret traversed all the way around and facing the viewer, the commander looking that way etc. As such, the pattern on the tracks are backwards if the modeler is placing them on while looking at the FRONT of the tank. V's going up seen from the back, pointed down seen from the front.
When you paint the wheels OFF of the tank, spray them black. Then use a circular stencil like a circle template to spray the centers green.
Have you ever done a quick build before? For those I plan the sequence ahead. Start by painting any stuff that needs dry time, say for a second color to be masked and applied. That'd be the wheels. Other than that, this is pretty much a shake-the-box kit.
