How to cut track links off of the sprue without breaking them?
    July 2008
Posted by castelnuovo on Sunday, December 18, 2016 11:47 PM
Gentlemen, I need a bit of a help here. I am building MCI Maultier in 1:35 and now I am at the point where the tracks need to be instaled. The track links are, as you can see, attached to the sprue in 5 points. There are 40 of them, but only 36 will be needed.
They are extremly fragile and I have alredy broken 2 trying to cut them of the sprue. Any suggestion how to cut them off without breaking them?
Thanks...
    July 2004
Posted by stikpusher on Monday, December 19, 2016 1:01 AM
Use a piece of foam behind them to relieve pressure and to use as support. I would try to use a new xacto blade with multiple light pressure cuts. It will be tedious and time consuming.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    May 2009
Posted by Pawel on Monday, December 19, 2016 3:06 AM
Hello!
My tip would be to use razor saw to cut the sprue attachment points (at least partially 3 of 5, then the rest could be done with a side cutter) and then file the remains off. Good luck with your build and have a nice day
Paweł
www.vietnam.net.pl
    August 2015
Posted by SpursN17 on Monday, December 19, 2016 4:56 AM
Try using a hot knife?
    November 2004
Posted by Bronto on Monday, December 19, 2016 9:53 AM
Use a small, thin saw.
    November 2016
Posted by Poniatowski on Tuesday, December 20, 2016 9:35 AM
I agree with Pawel. A finger nail clipper also works as a side-cutter.
Cheers!
Ron
Posted by HeavyArty on Tuesday, December 20, 2016 10:33 AM
A flush cutting sprue cutter is perfect for something like this.  It allows you to get in close spots and snip connection points easily with no pressure on the part.
    July 2008
Posted by castelnuovo on Tuesday, December 20, 2016 10:25 PM
Thanks for the suggestions, gentlemen. Will try few and see wht happenes.
Cheers... Smile
Posted by Spamicus on Friday, December 30, 2016 6:31 AM
Sometimes it helps to cut the big sprue. As in your photo the thick ones to the left and right of the piece. It doesn't always work, but that's where I usually go first.
Steve
    May 2011
Posted by Real G on Friday, December 30, 2016 12:15 PM
I second the hot knife.  Or you could get one of those narrow jaw sprue cutters like the one by Volks:
http://cs.finescale.com/fsm/tools_techniques_and_reference_materials/f/23/t/163607.aspx
“Ya ya ya, unicorn papoi!”
    April 2016
Posted by GlennH on Friday, December 30, 2016 12:21 PM
Spamicus
A hot knife also came to mind. I did find that with some parts even using brand new flush cutters I had broken a couple small parts. Cutting the main sprue in certain places did help if done in the right locations. It eases the tension being applied to the part as it's being cut.
A number Army Viet Nam scans from hundreds yet to be done:
https://www.flickr.com/photos/southwestdreams/albums/72157621855914355
Have had the great fortune to be on every side of the howitzers.
    June 2014
Posted by Tanker - Builder on Friday, December 30, 2016 12:49 PM
I think I can Help ;
    Having just finished with some German made , many small part , circus stuff for the museum I solved the problem . As suggested I cut away the heavy sprue and then used a very fine nosed side cutter to remove the parts . I got my side cutter from H.L in the jewelry dept .
 Why ? Well I have looked at and bought many of those advertised . They do NOT come together flat on one side .There is always this in profile ><, when one side needs to be this -- . The ones from hobby lobby have a fairly thick profile which can gently ground away giving you very thin tapered nose blades .
     What I also did was go to my Pharmacy ."Foot care section " . They have Toe-Nail cutters that are like oversized finger-nail cutters with the curve in the blade in reverse to the finger ones .You can grind a notch in one side to use these like sprue cutters .
   I had one of those pairs of cutter/tweezer, like cutters that worked super great and I have found they developed legs and walked off .Gotta get new ones . There you go - Good luck .T.B.
    July 2008
Posted by castelnuovo on Friday, December 30, 2016 9:52 PM
SpursN17
WINNER!!! Worked like a charm with hot exacto knife. Only one broke.
Cheers...Smile
Posted by Rob Gronovius on Friday, December 30, 2016 9:56 PM
castelnuovo
SpursN17
Cheers...Smile
I got one of these sprue cutters about 15 years ago. It was $10 back then, well worth the money. I also have a larger one Gino posted for bigger jobs.
http://www.micromark.com/Tweezer-Sprue-Cutter-Despruing-Tweezer,8012.html?sc=WGB&utm_source=GoogleBase&utm_medium=feed&utm_campaign=GoogleBase&gclid=CLPW987EndECFRMlgQodw9QNOQ
    April 2005
Posted by JohanT on Saturday, December 31, 2016 7:23 AM
Hi,
I usually cut up the thicker sprues in order to take out the stress when cutting the attachement points with a Xuron cutter.
Anyway - I see you have solved the problem, just my 2 cents
Best Regards
Johan
