Amusing Hobby Panzerkampfwagen VII Lowe
    December 2016
Posted by Foxhound500 on Friday, December 30, 2016 5:16 PM
I started this one a few months ago and then got married in Oct. so ive been away from it for awhile. Its mostly just waiting to be painted.
Posted by tigerman on Saturday, December 31, 2016 1:09 PM
Post some pics if you can. This should be a beast of a build.
 Eric
Posted by Bish on Saturday, December 31, 2016 2:15 PM
I like to see this as well. Got this in the stash and looks a really nice kit.
    December 2016
Posted by Foxhound500 on Saturday, December 31, 2016 2:28 PM
Here is the box.
Not too bad on parts. Comes with metal barrel. PE. Workable tracks. And clear parts.
This is the look we are going for.
I have torsion bars installed. I thought they were really cool as the suspension actually works with this kit.
Alright I chose to install plastic fenders because they were detailed enough for me and the pe ones were really thin.
It has been a very enjoyable build. The only aggrivating thing about it was drilling all the holes out. It has made me want to invest in a mini electric drill thats for sure. and fitting the upper hull to the lower and getting rear plate all lined up at the same time wasnt as bad as i thought it was gonna be. The tracks really impressed me. They were tedious to build but were worth it. The details with them were strong and they are workable and when installed have a nice realistic sag. So right now i am still waiting on paints. The engine bay does open. I was very disappointed when you open the engine bay there is nothing there. So i decided to add the engine that wouldve come in the tank. I picked up a cmk king tiger engine set. Hopefully i can make it fit and work. The engine has arrived today. I will work on assembling it and test fitting. Paints will be here next tues. I am kind of nervous about attempting the tri color ambush camo as i am new to AB. Also making the switch from MM enamel to acrylic paints. Paint stash is very small even with the MM enamel i have. Returning to the hobby has been great but getting paint is a pain for me because the paints i want are not sold locally. So i get halted quite a bit.
Posted by Bish on Saturday, December 31, 2016 2:44 PM
Nice start there. I had to do the same on the muzzle of the Trump E-100 have you thought about replacening the letterbox MG flap with a ball mount?
Looking forward to more.
    July 2003
  • From: On my kitchen counter top somewhere in central North Carolina.
Posted by disastermaster on Saturday, December 31, 2016 7:15 PM
I've got that kit too, and I've queued it for a future project.
 My only beef with it is where the main hatch on the turret is located.
When that main gun fires, someone is going to get a major squashing.
                                                            http://www.sherv.net/cm/emoticons/yellow-face/hit-by-cannonball-smiley-emoticon.png
 I'll be relocating that hatch from the 6 o'clock position to the 9 o'clock position......
wouldn't be hard to do.
                                                            http://i20.photobucket.com/albums/b232/gluetank/Animated/Disastermastermotion-3.gif
 https://i.imgur.com/LjRRaV1.png
    December 2016
Posted by Foxhound500 on Sunday, January 1, 2017 1:58 AM
We have modelled into the new year. Just finished installing engine. Let me tell you what a PITA it was dealing with cmk's kit. Wow... the amount of material that must be removed. Also kiss the little hoses that come with the kit goodbye cause they are going to break. The material they use to mold this stuff was too hard to but cut without breaking. Luckily. Most of this stuff will not even be seen.
and its assembled. I omitted hoses as they well broke...
Its not perfectly aligned as i wouldve wanted. but i had to do alot of trimming to make it fit. This was for a tamiya kit but this little engine project was a bigger job than expected with all the trimming that had to be done.
and one with engine hatch closed.
I may tinker more with it when more time is available. Still waiting on paints for exterior. TO BE CONTINUED....
MrT
    December 2010
Posted by MrT on Sunday, January 1, 2017 2:03 PM
Looking good!  Can't wait to see more.
Terry
Posted by tigerman on Sunday, January 1, 2017 8:15 PM
Coming along very nicely. Don't be too intimidated with the camo scheme. Turn your AB pressure down when doing the camo colors. Practice on some spare plastic cards or some cardboard before you try it on your tank.
 Eric
    December 2016
Posted by Foxhound500 on Sunday, January 1, 2017 8:28 PM
tigerman
Thanks! Yea gonna try to turn it down super low. Problem tho i need to add a tank to my compressor. I have a iwata smart jet and love it but hate the bleed valve. Keeps my compressor running alot and it gets pretty warm. Finding a small tank is a challenge. I could use a tank for a air horn setup but meh. Some of them are pricey and i would like to mount compressor on top of tank to keep it mobile. Thought about getting one of tcp globals setups and just take the cheapo compressor off and install mine. Then keep the cheapo for a spare. Just moneyd out for the month. I still need some more paints. I also need to get the AM parts for my upcoming project the dragon maus. I started on it some just to pass time as paints for this one should be here tuesday. Getting frustrated with not having the paint i need.  Will be glad when i can say i have enough paint to do most of the german tanks so i could put that money toward more kits and the AM parts i want on some of them. Would be really glad to have one on the bench just once i had everything i needed. Then i could source parts and materials needed for the next one while im working on one so i dont get halted.
Posted by Gamera on Sunday, January 1, 2017 8:48 PM
Neat AFV and good looking work so far on both her and the engine. Yes
    December 2016
Posted by Foxhound500 on Wednesday, January 4, 2017 11:38 PM
The paints have finally arrived!
No im not a fanboy. I just use what is easy and know works well for me. Yes i have a cheater's mindset. If it gives me the extra edge i need ill take it. Very pleased with these paints. So i have began to prime most everything tonight. I gotta go do a little more priming on the wheels.
I was extremely pleased to find that the primer sprayed perfectly straight out of the bottle and did so nicely i thought. I'm new to AB so i was very proud of myself to not have any issues with uneven paint or spattering or anything. I will say this. With the camo scheme i am going for. If I knew that it would take this long to prime everything i would have definitely used dark yellow primer instead of black to use as a base coat.
I have to go back tomorrow and hit the back of the wheels. I already have tracks primed and ready to go. I am very glad to have switched to acrylics. No odor. Also so much easier for me. I know i know. This isn't a very entertaining part of the build. I just wanted to update so you guys don't think i died at the bench and left y'all hanging.
    December 2016
Posted by Foxhound500 on Sunday, January 8, 2017 12:41 AM
Well... I'm very dissapointed. So i think i painted my camo too big if that makes sense. Needless to say im not happy with it. I wanted to use rotbraun but AK's is orange... my tracks i am happy with. I may try and get some putty and redo it. I don't know. Heres what i got any suggestions or critques would be extremely helpful and appreciated. I did freehand the entire pattern but as i said it looks too big and looks like a generic 90's U.S. Army camo scheme because i used Schokobraun.
Posted by tigerman on Sunday, January 8, 2017 12:30 PM
I like it. Once you put on the ambush dots and weather it, it will look great.
 Eric
    December 2016
Posted by Foxhound500 on Sunday, January 8, 2017 12:39 PM
Thanks. I gotta do some touch ups here and there. Got some yellow bleeding through and some overspray that needs to be taken care of. I need to knock the shine outta it. I'll give it a go.
    September 2012
Posted by GMorrison on Sunday, January 8, 2017 12:44 PM
It looks good. Weathering will blend it.
Posted by Gamera on Monday, January 9, 2017 12:02 PM
I don't know how accurate she is but she looks really cool.
    December 2016
Posted by Foxhound500 on Monday, January 9, 2017 12:47 PM
Thanks. And yea as i said i wasnt exactly thrilled with the camo. It wasnt what i wanted exactly. I freehanded with a airbrush  and before i knew it this is what i produced. Considering ive never done any type of camo before and used no masking in that regards im semi happy with it. I also used a iwata revolution cr. Surprisingly enough with the .5mm needle i was able to produce this. I am currently figuring out how i want to go about weathering and dulling the tone of the paint to make it blend.
    April 2015
Posted by RudyOnWheels on Monday, January 9, 2017 2:21 PM
Looks like a nice kit, and I think youre doing a GREAT job, especially being new to the AB. I am also new to the AB, and I just did a camo job on a Tiger 1, I wish I would have turned the presure down some, now that you mentioned it! Keep up the good work-
 Rudy
Posted by Bish on Monday, January 9, 2017 3:11 PM
I rather like that, the scheme has come out well. For weathering, you could start with a light coat of very thin yellow.
    December 2016
Posted by Foxhound500 on Monday, January 9, 2017 6:18 PM
Thanks everyone. and yes turning the pressure way down was key. I used ammo and ak paints. Both are thinned for airbrush. I had my pressure even lower for finer lines and thinned the paint slightly more. not much. Was blown away by my 90 dollar starter airbrush lol. Just took my time and built up the lines I will say it probably would've been easier with a hp-c+ as i have tried my buddies a couple of times and really liked it and did well with it. And alright since returning to the hobby ive only built 2 tanks. So weathering is still at a loss for me. I will need to purchase weathering supplies next month and im currently researching how to dull the color down and what order to lay down coats as in varnish and how to go about weathering using filters washes pigments etc. Then decide how i want to weather it. I know i definitely do not want to go with heavy mud. Maybe dust. but to me the mud would take away from the tank and the detail. also no chipping. I mean this tank was never produced so in reality it may have been built in '46 so no real wear and tear. Maybe some slight wear on hatches. But hey any advice is welcomed. I know this isnt the thread but I'll take what i can get. I will update again soon. Not gonna leave you guys hanging.
    March 2015
Posted by Toshi on Tuesday, January 10, 2017 4:12 AM
Nice job on the freehand camoflauge especially for your first time doing that.
Toshi
On The Bench: Revell 1/48 B-25 Mitchell
Married to the most caring, loving, understanding, and beautiful wife in the world.  Mrs. Toshi
    November 2004
Posted by snapdragonxxx on Thursday, January 12, 2017 6:29 PM
I've built this one and it is a nice kit.
I admit to getting some of the colours wrong but when I did this I was going though a quite bad PTSD episode and so wasn't really paying attention to the detail!
However, I have another one in my stash (somewhere) and will be building it in the correct specified March 1945 colour shades.
I think members will be somewhat taken aback by what will come out when I do it but the colours are quite accurate and none of this Mig Ammo/AK shade compensation nonsense.
Kate last year I made a research trip to the archived in Freiburg to look at paint chips, orders etc and came across a document with the company who made and supplied the paint to all 3 arms and by using the web found that they were still in business and still making paint.
My spoken german is not very good, but good enough to get a pint etc and a friend of mine made contact and got permission to visit to look at their archives.
In their archive there are batch samples and chip samples of every colour they made throughout the war and it is a fantastic record to look through. I cama away from the firm with new samples of the paint made for me from the original recorded pigment/formulae etc and had a local paint factory (my father knows the directors father - they play golf together!) make up several bottles of each colour sample for me (airbrush ready) and so I am now ready to tackle German armour with truly original paint colours!
Here's a hint. Dunkelgelb (RAL 7023) was only dark yellow for the Kursk offensive (operation Citadel) and was known as Dunkelgelb Nach Muster (Dark Yellow After Pattern) when it was accepted into the RAL register the colour was different but the name remained the same. It is really a brownish shade and changed a few times.
For my Lowe build, when I do it I will also be using Friul tracks and obtaining a metal barrel.
    December 2016
Posted by Foxhound500 on Sunday, January 15, 2017 4:03 PM
Your kit did not come with a metal barrel? Also yours looks nice.
Posted by Bish on Sunday, January 15, 2017 4:13 PM
Foxhound500
Mine didn't eaither, and none of the reviews i have read mention it. But it does come with a one piece plastic barrel, as it its not in 2 halfs just the 2 ends, so thats as good as a metal one.
    December 2016
Posted by Foxhound500 on Sunday, January 15, 2017 4:18 PM
Strange. Mine did. I don't see a need for metal tracks with this kit tho. The plastic workable tracks are pretty detailed. I sprayed mine with rust. Then used dark steel pigment to highlight. Pleased with the result. I am waiting on funds to purchase weathering supplies and varnish. Gonna pick up a iwata HP-C plus also. and a few addons for the maus build to be coming next.
Posted by Bish on Sunday, January 15, 2017 4:56 PM
I don't see the need for metal tracks either. Normally i go all out on AM and i had planned on getting the Voyerger PE set. But once i saw the kit, i decided not to bother. I am going to change the exhausts and fit a ball MG instead of the letterbox one the kit has, but other than that, the kit looks just fine as is.
    December 2016
Posted by Foxhound500 on Sunday, January 15, 2017 9:18 PM
I wish i never looked into AM stuff Sometimes.  Take the price of the kit. Add in pe. Add in metal tracks. Add in metal barrel. Some go all out and get masks. Books. By the time youve gotten all of that you are out some money. Isn't bad when you have a good stash of paints and every tool needed for the hobby. But if you don't that wallet could ache. found i want a new iwata hp-c plus and stencils by alliance.
Posted by tigerman on Sunday, January 15, 2017 11:29 PM
Foxhound I hear you on AM. I bought a Tamiya Semovente at a show for $6. I then bought an AM barrel for $7 and some AM tracks for like $27. LOL Almost 6x the cost of what I paid for the kit on AM, but it needed it, I just wish I bought some AM lights.
 Eric
Posted by Bish on Monday, January 16, 2017 6:09 AM
I used to buy my AM at the same time asi got the kit. But then i did a couple of Dragon panther kits with Voyager PE and realised i had wasted my money as thekits didn't need it. Now i am a lot more selective and wait until i get the kit before getting what it needs rather than everything thats avaliable.
