Another Panther question
    October 2009
Posted by Kentucky Colonel on Tuesday, March 28, 2017 5:24 PM
While doing research on Panthers I came across several pictures of both real Panthers and models of Panthers that had extra sheets of rusted steel on the top of the turret, the top of the tank and on the air intake in the back. I'm guessing this is extra armor put on by the crews?  Anybody have any info I just don't know Panthers that good. Are there certain model kits that have this and/or there any PE lits and which Panthers use it??
    July 2003
  • From: On my kitchen counter top somewhere in central North Carolina.
Posted by disastermaster on Tuesday, March 28, 2017 10:34 PM
Save your cash. Those plates would be a simple scratch built item.
http://www.griffonmodel.com/uploadpic/Products/20083192565666719.jpg                                                          http://i20.photobucket.com/albums/b232/gluetank/Animated/th_1-Animated-Disastermaster.gif?t=1296616998
 https://i.imgur.com/LjRRaV1.png
    December 2012
Posted by Ixion on Tuesday, March 28, 2017 11:37 PM
Listed as "modifications after issue to the troops" to be performed by field units; "Starting in December 1944, fabricate protective covers from pieces of Schuerzen and install the covers for the rear deck." - Jentz, Germany's Panther Tank, page 102.
While generally fitted to late Ausf G's at this date, they could be fitted to existing earlier models as well, although photos of this occuring might be hard to find.
This was also done on a limited basis to the turret roof, usually with sandwiched pieces of scrap armor sheet.
Posted by Bish on Wednesday, March 29, 2017 2:09 AM
I'll go with what DM says. Unless your buying a larger PEset which includes these, and several company's do, you can make your own with some thin sheet stryene.
    September 2005
Posted by warshipguy on Wednesday, March 29, 2017 5:59 AM
Tamiya once released a special edition Panther G with a photoetch set that included those plates.  I don't know if they still have it, but it makes for an interesting model.
Bill Morrison
    August 2005
Posted by Phil_H on Wednesday, March 29, 2017 8:46 AM
Voyager has this as an add-on. This set includes the turret top armour.
http://www.voyagermodel.com/productdetails.asp?itemid=PEA065
