Opinion needed for my M3 Stuart build
    February 2015
Posted by acctingman on Monday, August 14, 2017 11:08 PM
I'm working on my second build (Tamiya 1/35 Stuart). I've gone with a solid Olive Drab base.
I'm wondering how I shoud handle weathering the lower hull. I'm wanting to go for a more grimy look. I'd like to use oils on the hull to simulate rainy grimy weather. How should I tackle the lower hull/wheel area?
Thanks
    July 2004
Posted by stikpusher on Monday, August 14, 2017 11:19 PM
That area on a tank gets pretty filthy. I like to use the earth tones like Sienna's or Umbers there, depending upon what look I'm trying to create, dry dust or wet mud.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    September 2013
Posted by Marcus McBean on Tuesday, August 15, 2017 6:40 AM
The paint should be a little darker on the lower hull than the paint on the upper hull, decking and turret.  They upper parts of the tank is exposed to the sun more.
    February 2015
Posted by acctingman on Tuesday, August 15, 2017 8:31 AM
Thanks!
I think this gives me a good idea how to approach this area.
Posted by Gamera on Tuesday, August 15, 2017 11:17 AM
As an alternate to pigments there is a 'stucco' type textured paint I like to brush on for mud and then paint. The results aren't as good but personally I find it easier to use.
    April 2006
Posted by jgeratic on Tuesday, August 15, 2017 1:50 PM
Another method for a dusty and slight build up of dirt on the lowers is to lay the model on it's side.  Sprinkle appropriate coloured weathering powders on hull, then on the edges add Tamiya acrylic thinner (the one that smells like rubbing alcohol) with a large brush.
Once the entire hull side is soaked, return it to proper sitting position and let the excess drain downwards, causing natural streaks.  Repeat for the other sides.  Can also embelish further with downward brushstrokes both wet and dry.
regards,
Jack
    February 2015
Posted by acctingman on Tuesday, August 15, 2017 4:01 PM
Jack
That looks amazing. Thanks for the tip.
Thanks to all
