Rob Gronovius
You also have to clarify by what you considered "older". I was thinking about their kits from the 1970s and 1980s that were often designed to be motorized.
Yes, I was referring to the old 70s kits that you can pick up for very cheap. The old Tigers, Hanomag, etc.
The Easy Eight that I built is the newer 2015 release. It was excellent. I assume, however, that level of fit and finish is only available on the newer more expensive kits.
