M3A3 Kinetic 1/35 WiP
    March 2017
Posted by MattSz on Friday, March 2, 2018 6:03 PM
In this threadI will show the build progress with the new Kinetic M3A3 Bradley in 1/35 scale.
I also did the video review of this kit:
https://www.youtube.com/watch?v=akSEuwLhc6I
In this album I placed the in-box photos if somebody is interested:
https://www.facebook.com/pg/MattSzMiniatures/photos/?tab=album&album_id=763869067137491
The box art:
I started work with the kit from the wheels. They comes from four five each: the outer and inner rim halves, two rubber tires and pool cap. All plastic parts have four connection points with the sprue so cleaning and sanding them require some time.
The assembled wheels. Details are ok. Sprockets had connection points on the end of tooth so they are easy to cleanup without any damage. Wheels contains the poly caps inside so they could be easily removed for the paint process.
Next I started work with the suspension and return rollers. It also comes together and line up without any problems. Return rollers also fit perfect in their places.
Everything on it's place. It's a pity that side skirts hide almost all suspension details.
Evening work with the track. They doesn't look very convincing on the sprue but overall work with them was fast and the effect is also good. To make them removable for the painting I do not glued the top section, it's just dryfitted.
I shaved off the pinmarks on the inner side of the tracks and just glued indyviduwal sections and separate links together. The separate links used on the sprockets and idlers are a little curved so they look really natural in these places.
I also glued the rear plate with door. I'm very happy how the lower and upper hull fit together. The good fitting between these two parts is important because I can take off the upper hull for the painting and glue these two parts together after paint track and wheels section.
The hull slowly takes a shape.
More soon...
Posted by Rob Gronovius on Saturday, March 3, 2018 9:32 AM
Looks good, I've read that this is the former Orochi kit.
    March 2017
Posted by MattSz on Saturday, March 3, 2018 3:57 PM
Rob Gronovius
Yes and no.
Most plastic parts are exactly the same like in the Orochi kit but this sprue is made by Kinetic:
Posted by Rob Gronovius on Saturday, March 3, 2018 6:16 PM
I know they replaced the individual track links with link and length, a much better option since 2/3rds of the track is covered by side skirts.
Posted by HeavyArty on Sunday, March 4, 2018 10:07 AM
MattSz
 Most plastic parts are exactly the same like in the Orochi kit but this sprue is made by Kinetic...
Some of the parts on the other sprues have been reworked as well to make this a very nice kit.  It is much better than the Orochi version and fixes pretty much all of the issues it had.
What version do you plan on making of it?  Just so you know, the ERA has not been used opeartionally with the new T161 tracks.  Also, if you leave the ERA off, you should fill the two holes on each front side skirt panel.
    March 2017
Posted by MattSz on Monday, March 5, 2018 4:15 PM
Rob- yes it was a good move- the track assembly takes not longer than hour :)
Heavy Arty- this is really nice kit indeed, I do not work with Orochi but I heared that people complain about this kit. This Kinetic relase comes together really nice.
Yes, I did some research and read about it. I'm not very familiar with modern armour and I'm not a rivet counter so I just decided to paint this vehicle as interesting as I can. I want to paint my M3A3 something like this
Next portion of photos and my thoughts about this kit:
A little bit of progress with the build. I installed the side and front BUSK III armour. On the front plate before the additional armour I made bracing for it.
The ERA armour panels fit well, only on a few places I used a little bit of putty. It was not neccessary but I want to make sure that after primer coat there will be not any visible gaps.
The same on the rear. I used putty just to avoid corrections after primer painting
 Next I installed the front lights. They are wll detailed but I decided to add some electric wires to increase a detail level.
When the BUSK III was finished I started to add other details, almost all of them fit in their places without any problems. Only the lifting brackets had too thick positioning pins, so I just cut them off.
The hull assembly process was rather fast, only this step require some time and patience. You need to shave off from the sprue twenty small rivets and glue them on the model. I don't know why the producer moulded them separatelly not on the main upper hull part like the other ones.
There are the "special" separatelly moulded rivets on it's place.
The right side of the hull is not as bussy as the opposite. The big PE mesh parts attract the attention. These parts are really thin and well made.This kit contain only a few PE parts, I do not like espacielly work with them so I'm happy with it.
The hull assembly is finished. I only need to add the front and rear mud guards and periscopes but I paint them separatelly and add after base coat painting.
Work with this kit is a pleasure so far. I'm glad from the detail level in this kit, I hope that the turret will go together as good as the hull.
As I wrote before I leave the upper and lower hull as separate components. It let me easily paint the suspension and tracks.
Posted by Gamera on Wednesday, March 7, 2018 7:28 AM
Nice work!
Never built any of the Orochi* kits but the one Kinetic one I've worked on had great detail but bad fit problems.
No idea if any of this is accurate or not but the detail looks fantastic!
*The name always made me laugh because Orochi is an evil company creating fun stuff like genetically-engineered monsters and bent on world dominion in 'The Secret World' online computer game.
    March 2017
Posted by MattSz on Wednesday, March 7, 2018 5:46 PM
I do not know about it :D
This is my first Kinetic kit and comes together as a dream, very good engineered.
I started work with the turret. The quality of all parts is the same as previous- very good.
I mounted gun barrel, it comes as one piece so it's easy to cleanup and look good, in my opinion aftermarket barrel is not neccessary.
I also drilled the coaxial mg barrel.
As you see all plates fit together very well, I used putty only in a few small spots.
    March 2017
Posted by MattSz on Tuesday, March 13, 2018 4:42 PM
I finished the turret construction. Overall it comes together nice but I got the impression that a little bit worse than the hull. The most problematic was the 2 era blocks that do not fit properly, finally I used putty in this area.
I really like the final turret look. It is very busy and well detailed. I don't installed the periscopes, I will do this after painting.
The assembly process is finished, now I will wash all model in water with detergent and apply primer.
    October 2004
Posted by ygmodeler4 on Tuesday, March 13, 2018 5:57 PM
Looking good
-Josiah
Posted by HeavyArty on Tuesday, March 13, 2018 6:32 PM
Looks pretty good.  One mistake Orochi made and Kinetic left is the backup sight that is the tear-drop shaped PE part w/the reticle on it.  It should be clear plexiglass, not solid PE.
Posted by Gamera on Wednesday, March 14, 2018 7:34 AM
Oh wow, looking really nice!
Lotsa detail there for washes and drybrushing!
    March 2017
Posted by MattSz on Tuesday, March 27, 2018 5:36 PM
Hi after small break.
I took Bradley to the International Festival in Bytom last weekend where I used it to test Tamiya LP paints.
They are the results:
 I spray black and white paints directly to the plastic and pe parts. They work very well and do not required any primer.
After airbrushing black and white I used brush and white color to highlight details.
I did the same on the wheels.
Tracks are primed with Ammo One Shot and then I covered them Vallejo Track Primer paint.
    November 2008
Posted by mrmike on Tuesday, March 27, 2018 7:52 PM
That's a very good looking build! Thanks for posting the process; looking forward to your painting and weathering.
Posted by Gamera on Wednesday, March 28, 2018 11:58 AM
Cool!
Most photos I've seen the guy used light in the center of the panels and the dark on the outsides. Looking forward to seeing how yours comes out. I might have to change how I've been doing things.
