Dragons 1/35 Tiger 6383 W Zimmerit, getting started.
Hi,
To make a long story short I have finally started on this kit after allowing it to mature in a wardrobe for almost a decade.
And found a couple of twirks I did not expect.
The gap between the bottom plate and rear end plate is me. I did not allign that carefully enough.
But the thing I would like to ask you guys is this:
The hole plate is covered i.e, the exhaust covers and heat deflectors are sitting on a rippled surface? Is this correct?
Also the smal brackets in the front supporting the drive wheel gearboxes are sitting on rippled surface?
I have a set of ATAK Zimmerit that I bought for 6253, the release prior to 6383 that came without the injection molded zimmerit surfaces.
This set definately has cutouts for the bolted on parts.
I don't realy want to carve of the stuff, just not sure if I should try to put some putty on to make the parts "sink" into the rippled surface.
Very Best Regards
Johan
