halftrack tracks
halftrack tracks
Posted by RAF120 on Friday, April 2, 2004 9:35 PM
I have one of Tamiya's US halftracks that I build a while ago. I would like to redo it, but I don't like the tracks they're to loose. What I would like to know are there are some aftermarket tracks out there that fit better, or is there some other fix to this problem.
Trevor Where am I going and why am I in this handbasket?
Posted by Anonymous on Friday, April 2, 2004 11:07 PM
Would it be possible to remove a track link or two to tighten them up a little?
    December 2003
Posted by spector822002 on Friday, April 2, 2004 11:59 PM
A company by the name of AFV club makes some pretty good AM tracks for american armour , I am not sure if your vehicle is there , but I would guess it would be Try http://www.greatmodels.com in the maufacturers link to the left go to armor accessories well you know the rest , keep in mind with this company however if it is not in stock you may have to wait a bit for it . Good luck in your hunt .
Posted by Anonymous on Saturday, April 3, 2004 1:24 AM
wqhat i did was cut the connector ends off and tie with thread the ends together. works
Posted by Anonymous on Saturday, April 3, 2004 3:01 AM
i dont think theres any aftermarket tracks for it
they were rubber band track in real life anyway so you might have to do as warmongers pointed out
Posted by Rob Gronovius on Saturday, April 3, 2004 9:36 AM
Tank Workshop made a set of resin tracks for the M3 halftrack series. I saw them at a local store in 2002, but passed them up. They did not look too good and would have been a PITA to work with.
AFV Club does not make US halftrack tracks. They do have US light tank and German halftrack tracks in their product line though.
Posted by jeepman on Saturday, April 3, 2004 11:24 AM
I have used the Tank Workshop resin tracks,as Rob says they can be a PITA.You just have to take your time.I used both hot water and a hair dryer for final shaping.They are basically just resin copies of the kit tracks,IIRC I had to shorten them also for a good fit.The set has replacements for the drive sprockets and idlers.They take a lot of cleanup but are a definite improvement over the lumps of plastic Tamiya gives you.Happy modelling!!!!
Posted by RAF120 on Saturday, April 3, 2004 4:09 PM
Thanks for the help. It looks like I'll have to try warmongers idea. If that fails I know I can always try Tank Workshop.
