RMSh tracks that fit Tamiya's T-55A kit?
    December 2017
Posted by KyleBragger on Tuesday, August 20, 2019 10:32 AM
Anyone have a recommendation for RMSh aftermarket tracks that fit Tamiya's T-55A 1/35th kit? I suspect I may need different drive sprockets. I've tried Miniart's so far and they're too wide. Modelkasten *almost* fit but not quite.
    July 2004
Posted by stikpusher on Tuesday, August 20, 2019 12:32 PM
I would say have a look at Trumpeters T-72 tracks. Their T-55 Omsh tracks fit perfect on my Tamiya T-55. But yeah, a replacement sprocket will likely be needed.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    May 2011
Posted by Real G on Tuesday, August 20, 2019 1:37 PM
Sector 35 makes a pre-assembled metal RMSH track set:
https://hobbyterra.com/product_info.php?products_id=4258
Pro:  Pre-assembled tracks mean minimal assembly.
Con:  The people assembling the tracks have CA glue all over their fingers.  Since CA is clear, you can't see a thing at first.  But if you use a blackening fluid, the CA smudges on the tracks will prevent the areas from changing color.  If you paint your tracks, no biggie.
I have used Sector 35 tracks on several Tamiya tanks (Churchill, Cromwell, IS-3), and they all fit with no mods to their sprockets.
HTH and good hunting!
“Ya ya ya, unicorn papoi!”
    December 2017
Posted by KyleBragger on Tuesday, August 20, 2019 1:42 PM
I've actually got some sector35 RMSh coming (eventually...)  I've used for some other kits and they're great. Have you used on the T-55 kit?
I've got some CA remover handy, that's good to know though. I've not had issues quite yet but thanks for the heads up!
    May 2011
Posted by Real G on Tuesday, August 20, 2019 3:02 PM
I actually do have a Sector 35 RMSH track set and a Tamiya T-55, but they are just stowed away together in the stash.  I have not checked if the tracks will fit the kit sprockets.
