Who Makes A Good Steel Color Paint For Doing Tank Suspension
    August 2019
Posted by johnfromiwo on Saturday, September 7, 2019 1:52 AM
Im Doing A M3 Stuart And For The Idler And Return Rollers They Were A Steel Color. So What Brand Makes A Good Steel Color For Brushing?
You Got A Tank In Me You Got A Tank In Me When The Road Is Up Ahead And Your Miles And Miles From Your Nice Warm Bed.Just Remember What Your Old Pal Said Cause You Got A Tank In Me LOL----happy modeling
    May 2013
Posted by hogfanfs on Saturday, September 7, 2019 7:26 AM
I use Testors Model Master Steel #1780
 Bruce
 On the bench:  1/48 Eduard MiG-21MF
                        1/35 Takom Merkava Mk.I
Posted by Tojo72 on Saturday, September 7, 2019 7:44 AM
Not sure what effect you are going for,bare unpainted steel not in contact with anything would weather,or do you mean bare steel on the bottom of the rollers where the paint wore off
Tamiya XF-84 Dark Iron ?
    July 2004
Posted by stikpusher on Saturday, September 7, 2019 8:11 AM
Tojo72
The idler wheel was all steel, no rubber rim, so it would become a polished bare steel from use. Also the areas of the support skid on top of the bogie units, sprocket teeth, and end connector guide teeth would also get that look as well on metal to metal contact areas. Those areas can get pretty bright during use if not in muddy terrain. I like using Testors steel, or sometimes even add some Chrome Silver to brighten it up more.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    September 2012
Posted by GMorrison on Saturday, September 7, 2019 8:52 AM
Needs more rust.
Posted by Tojo72 on Saturday, September 7, 2019 12:29 PM
stikpusher
Tojo72
Yes,thats what I would use,like steel road wheels on Tigers,Panthers,and the like.For old untreated steel,I do like that Tamiya Dark Iron.
    January 2015
Posted by M. Brindos on Saturday, September 7, 2019 1:03 PM
Another effect that I like, besides steel and aluminum dry brushing, is painting the surfaces NATO Black and rubbing them with a graphite pencil. The effect has has a perfect sheen of rubbed steel.
You don't even have to use black as a base color. I've used a graphite pencil for all sorts of fresh/bare metal finishes such as hatch rims and warn contact areas on hulls and turrets. Works especially well for machine guns.
Test it out and see for yourself.
Oh, and if you still have any laying around, an old no.2 lead pencil will give a darker iron look. Easy effects to use and look realistic without much effort.
- Mike Brindos "Lost Boy"
    April 2016
Posted by GlennH on Sunday, September 8, 2019 11:54 AM
M. Brindos
I have used regular pencils often. Are you saying a graphite pencil is different than regular pencils?
A number Army Viet Nam scans from hundreds yet to be done:
https://www.flickr.com/photos/southwestdreams/albums/72157621855914355
Have had the great fortune to be on every side of the howitzers.
    January 2015
Posted by M. Brindos on Tuesday, September 10, 2019 12:11 AM
Graphite pencils are not the same, no. The artists pencils range from very soft to very hard.
    April 2016
Posted by GlennH on Tuesday, September 10, 2019 1:10 PM
Thanks. I will look for a soft one next time I get someplace that sells that stuff.
Posted by T26E4 on Wednesday, September 11, 2019 1:05 PM
GMorrison
Needs more rust.
Only if the Stuart hasn't moved recently.  Every time it moved, its idler and return rollers would be rubbed clean of any oxidation.
Roy Chow
Join AMPS!
http://www.amps-armor.org
