Takom PL-01: Polish Prototype Panzer
    May 2011
Posted by Real G on Tuesday, September 17, 2019 2:07 PM
The future of AFVs is here, in 1/35 scale:
The real thing is based on the Swedish designed CV90 IFV, which itself sports many variations from infantry carrier to light tank.  The Polish PL-01 is actually a mock-up showcasing various innovative features for proposed future AFVs, the most obvious being a stealthy exterior.  The turret features what look like self-defense mini turrets with sensors and countermeasures, and that diamond cross section gun cladding just jumps out at you!  The rooftop remote weapon station is now becoming standard on AFVs, and the turret is unmanned.  The panoramic sight is inexplicably tiny - current AFVs so equipped have these huge inverted bucket-looking things sitting on their roofs.  The razor-thin LED head lights are a cool new feature.  The instructions mention that water-cooled panels covering the tank help reduce IR signature.  It also mentions armor protection level effective up to 30-40 mm AP from the front, 14.5 mm all round.  That may not seem like much, but the PL-01 is in the 30-40 ton class which makes it a light tank by modern standards.  It does have a 105 or 120 mm auto loading main gun, so its firepower is equal to the larger MBTs.
Linky if you want to see what's in the box:
https://www.flickr.com/photos/ntizumi/albums/72157710885388828
And the short review is this:  Cool subject with minimal parts count!
Now to research the paint scheme on the actual vehicle - is it one color, or three tone splinter?
“Ya ya ya, unicorn papoi!”
    January 2015
Posted by PFJN on Tuesday, September 17, 2019 5:59 PM
Hi,
Thanks for the info.  I am looking forward getting a copy of this for myself.
Thanks
Pat
1st Group BuildSP
    May 2011
Posted by Real G on Tuesday, September 17, 2019 11:43 PM
Pat,
It looks to be a relatively straightforward kit with a low parts count.  I like that, versus a 1,200 part Panzer IV!
Not sure how picky I’ll get when it comes to cleaning up the bolts on the track ends.  The ones with the sprue connection will need new bolts, but like Ripley wiping down Newt’s face, I’m in trouble if I make a clean spot!
Posted by Gamera on Wednesday, September 18, 2019 11:30 AM
From your photos she looks to be a well engineered kit. So tempted to pick one up for myself.
BTW: Hope you're going with that insane digital camo in the first camo diagram!!!
Posted by Tojo72 on Wednesday, September 18, 2019 12:20 PM
Wow really cool.When I initially saw the post,I was thinking of some tankette from the 1930's
    May 2011
Posted by Real G on Wednesday, September 18, 2019 1:17 PM
Gamera - I was thinking a 3 tone splinter using blue-greys.  That digicam is too nuts!
Tojo72 - Yeah, it certainly isn’t Wehrmacht fodder!  Although to be fair, it’s just a mock up.  But what a cool looking mock up!
    February 2011
Posted by GreySnake on Wednesday, September 18, 2019 4:52 PM
Thanks for the info and a look inside the box. I’ll be picking one up for sure. It would be interesting to put that side by side with a Polish tankette from WWII once built.
    January 2015
Posted by PFJN on Wednesday, September 18, 2019 6:12 PM
Real G
Pat,
Cool, I just ordered one off eBay Stick out tongue
1st Group BuildSP
    August 2017
Posted by laskdjn on Friday, September 20, 2019 8:38 PM
Looking at it, I wondered why it had big foot tracks off of a Bradley or AAV, then I looked it up and saw the cv90 mk III was only 35 tons max...
    September 2006
Posted by RBaer on Saturday, September 21, 2019 10:39 AM
I've been real curious about this kit, looks like it should be a very nice build, interesting too.
Apprentice rivet counter.
    May 2011
Posted by Real G on Saturday, September 21, 2019 12:08 PM
Now how shall I complicate this simple build?  Stick out tongue
    February 2011
Posted by GreySnake on Sunday, September 22, 2019 4:50 PM
Digital camo?
    May 2011
Posted by Real G on Sunday, September 22, 2019 5:00 PM
Digicam looks spectacular, but it would make the PL-01’s fantastic shape less visible.  Kind of like applying it as body paint on a supermodel.  I’ll give the boys a moment to savor that image...
    May 2011
Posted by Real G on Friday, October 18, 2019 1:03 PM
I have been putzing around with the kit and started to assemble the hull and turret.  Being that there isn't much "stuff" on either is a two-edged sword.  On one hand, it means a fast and easy build.  On the other, the vast expanses of smooth surfaces demand precision fitting and seam filling.
The name of the game is fit and fettle.  The locator tabs for the front glacis and rear hull interfere with fit just ever so slightly, which is a common problem.  I heavily scraped down the contact points and got the outer egdes to more or less align.
The area over the tail lights was problematic, as when I got those areas to fit flush, the area over the rear boarding hatch had an overhang.  I'm going to scrape down the overhang and reestablish the faceting as best I can.
The turret has a two part insert for the recessed gunner's sight, and it fits poorly.  I tried fettling the the contact points inside the turret but still got gaps.  I have some careful puttying and sanding to do.  Not really visible is an ejector pin mark on the upper portion of the recess.  The photo shows the insert installed, but not glued in; I will try to tweak the fit further.
I also started redoing the main gun trunnion.  I cut away the fat short pins molded to the side of the gun and substituted a section of plastic tubing.  Work is still ongoing here, as I am thinking about making the gun slide in after finishing.  A polycapped damper ala Tamiya's new M551 Sheridan will prevent future need for Tank Viagra.
So here are some pics of the mock-up tank model, well, mocked up:
Posted by Gamera on Monday, October 21, 2019 7:40 AM
Oh wow she looks very high tech!!!
Strange she doesn't fit better though. Only Takom kit I've build it their T30/34 but the fit there was perfect. I used some putty but don't really remember any parts that were really off.
    May 2011
Posted by Real G on Monday, October 21, 2019 9:52 PM
Yeah, the fit overall is kind of wonky.  Not 100% wonky, but just enough to make stuff not look right.  Takom might have rushed this kit to beat out Trumpeter/Hobby Boss and Meng.
We had our monthly "hobby night" at my place this past weekend, so I got some work done.  Because of the annoying little fit issues, I decided that the hull should be assembled prior to painting.  Fortunately, the lower hull and complete running gear can be slipped in as a unit, so when the upper and lower hulls do join, there is only one visible join line at the front to deal with.
There isn't much to the outer surface of the turret and hull, so the detail parts went together quickly.  The remote gun has some ugly seams, so a few parts have not been attached yet.
Now I'm waiting on some articulated AFV Club M2/M3 tracks to arrive in the mail.
Posted by Tojo72 on Wednesday, October 23, 2019 6:12 AM
Making good progress !!
    September 2006
Posted by RBaer on Wednesday, October 23, 2019 7:47 AM
Neat looking. What kind of tracks are in the kit?
    May 2011
Posted by Real G on Wednesday, October 23, 2019 9:02 AM
Thanks Tojo72!
RBaer, the PL-01’s tracks are link and length.  The indie link AFV Club tracks showed up yesterday, so I spent the evening assembling them.  I’m not even half way through, so I’m eyeing the kit tracks again...
    May 2011
Posted by Real G on Wednesday, October 23, 2019 12:57 PM
I am learning that Ebay is useful for obtaining single items at a reasonable price.  These AFV Club M2/M3 Bradley tracks arrived at my door yesterday, a week earlier than expected from Taiwan.
So I spent last evening cutting and trimming instead of sleeping.  I noticed five things:
1.  The track pads are hard plastic, unlike the M41 set, which is a GOOD thing.
2.  The tracks fit the width of the sprocket perfectly and fit between the hull and skirts.
3.  There is a slight horizontal "bow" to the assembled tracks in one consistent direction when they are linked up.  This might be a problem.
4.  All that clipping and cleaning up of indie links is tiring!  I am considering revisiting the kit link-and-length tracks...
5.  Man, I should have gone to bed when I could have.
    September 2006
Posted by RBaer on Wednesday, October 23, 2019 1:17 PM
Ah, track joy.
Posted by Gamera on Thursday, October 24, 2019 3:16 PM
I normally clean up tedious stuff like track links and road wheels while watching TV or Youtube videos...
    May 2011
Posted by Real G on Thursday, October 24, 2019 6:30 PM
But if I start watching Youtube videos, I can't take my eyes off the screen whenever they play a Gwar song.  I have to stop everything and start singing!  Stick out tongue
For me, tedious stuff is best done during the wee hours of the night.  There are no distractions - the insane barky dogs across the street are sleeping, my two stupid neighbors' kids with their Subaru WRXs with the droning exhaust pipes are out drinking, doing drugs and racing on the freeway, no phone calls, etc.
I'm still nowhere near cleaning up all the aftermarket links, so the kit "link and length" tracks are looking better every day.
Posted by Gamera on Thursday, October 24, 2019 9:22 PM
Can't blame you, a little peace and quiet works wonders.
Considering the skirts cover about 40% of the tracks couldn't you cheat a little?
    May 2011
Posted by Real G on Thursday, October 24, 2019 9:52 PM
Gamera
Absolutely.
Posted by CapnMac82 on Saturday, October 26, 2019 7:51 PM
Real G
Dunno, but the shape of this thing just begs for a six-color WWI-style hexagon lozenge camo Smile
    May 2011
Posted by Real G on Saturday, October 26, 2019 11:27 PM
Ha ha Capt Mac, no “crazy quilt” paint for this one!  I’m leaning towards the actual grey-green single color scheme, although the digicam suggested by others is quite tempting!
    September 2006
Posted by RBaer on Monday, October 28, 2019 9:46 PM
Oooo, lozenge camo!
