stipp: My apologies for not responding sooner. The DAK (Dueschtes Afrika Korps) originally had grey vehicles but they were quickly overpainted with Sandgelb (sand yellow), either completely or with some grey left showing through in a disruptive pattern.
More pics!
The hull halves were hard to line up but I persevered.
I started at the rearmost plate on the left side and glued that ONE plate, after that had set I used Ambroid Pro Weld (This stuff wicks right into the seam.) on the next plate foreward and allowed it to run down the inside of the joint and held it while it set. Once this was dry I ran some down the inside of the front plate from the front again holding until set.
Then came the hard part. Starting at the right rear I followed the same procedure but had to push the parts in place as the lower hull panel edges were slightly narrower than the upper edges.
The final step was gluing the rear plate.
It is important to leave this to last to allow the lower hull to flex.
